2006 long hot starts
Old 07-23-2017, 11:17 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Ok so I started having long hot starts or no starts. I just watched the ICP and it took a long time to build up past 500. So would I just be going after stands and dummy plugs? Or should I look at something else first?
Thanks.
Old 07-23-2017, 12:45 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Thanks.
If those haven't been done that's where I would start. Has the STC fitting been replaced? If not I would do that one too.
Old 07-23-2017, 12:59 PM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Not sure on the stc fitting. Didn't they upgrade the stc's after 2005? I will definitely do plugs and pipes. Wasn't sure if I should look anywhere else.
Old 07-23-2017, 04:35 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
Never updated the STC that I have heard of, same fitting all the way through the '10 E series if I am correct.
An air test will confirm some thing for sure, you might also be a candidate for upper injector seals and nipple cups o-rings.
Adamre
08-15-2016 06:47 AM
cookingguy
02-01-2015 09:49 PM
firemanrob
12-18-2014 08:00 AM
aquanaut20
04-10-2006 01:00 PM
Quick Reply: 2006 long hot starts
