2006 long hot starts
Ok so I started having long hot starts or no starts. I just watched the ICP and it took a long time to build up past 500. So would I just be going after stands and dummy plugs? Or should I look at something else first?
Thanks. |
Originally Posted by Iaff113
(Post 17347399)
Thanks. |
Not sure on the stc fitting. Didn't they upgrade the stc's after 2005? I will definitely do plugs and pipes. Wasn't sure if I should look anywhere else.
(Post 17347555)
An air test will confirm some thing for sure, you might also be a candidate for upper injector seals and nipple cups o-rings. |
