6.7L Oil Filter Source?
Old Jul 23, 2017 | 10:33 AM
HRTKD's Avatar
HRTKD
I usually buy my oil and filters from AMSOil but not any more. I also buy in bulk to keep plenty on hand.
Where are you guys buying filters? I found the
Motorcraft FL2051S Oil Filter Motorcraft FL2051S Oil Filter
at Amazon for $17.08. I figure that as long as I'm going to buy a Motorcraft filter I should find the lowest possible price.
I also found a 12 pack that gets the price down to 14.94 each (free shipping). I was thinking a pack of 6 would do, but 12 wouldn't be unreasonable. It's not like they go bad.
Old Jul 23, 2017 | 10:53 AM
System's Avatar
System
Prolocutor
Best pricing on Motorcraft oil and fuel filters here. https://www.dieselfiltersonline.com
Old Jul 23, 2017 | 11:05 AM
HRTKD's Avatar
HRTKD
Thanks Rodney. $51.70 for a set of 4 oil filters, which comes in at $12.93 each.
That's a good price. Shipping is free as long as the order is for more than $250. I would have to either go in on an order with one of the local guys or buy a bunch of other stuff in bulk also.
Old Jul 23, 2017 | 03:28 PM
UGA33's Avatar
UGA33
If you are in a pinch and didn't have time to order, Walmart is the cheapest store front to buy the filters. They are way cheaper online though.
Old Jul 23, 2017 | 04:48 PM
DISLTom's Avatar
DISLTom
I buy the K&N HP-4005 on Amazon. $19 - free shipping.
Been using the HP-2010 on my F150 for years. Without the 1" nut on the end it is impossible to get off. Some doofuss decided it would be a good idea to put the filter above the front diff. Standard MO is to hand tighten. But it tightens itself up as time goes on.
There's no space to get any oil wrench up in there. So with the 1" nut it is easy peasy to take off. Even though it is still a little painful.
Old Jul 23, 2017 | 08:49 PM
Flyct's Avatar
Flyct
FTE Community Team
Thanks for posting this. I ordered a few from Amazon just now.
I have been using similar filters with 1" nut on bottom on Aircraft engines for years. It makes it so easy to break a filter free.
Before removing a filter I punch a drain hole in the bottom a small hole at the top to let air in while it's draining.
Old Jul 24, 2017 | 08:09 AM
malbanese45's Avatar
malbanese45
FL-2051S 13.99 at Advance Auto after discount code SCW227 . Pick up in store.
deadbug
6.4L Power Stroke Diesel
17
Mar 1, 2009 05:06 PM
wiingnut
Jul 29, 2006 09:50 AM
Lnd Svyr
Nov 21, 2004 02:18 PM
chandlerbf
Jun 28, 2004 10:04 AM
jcork
Oil & Lubrication
Sep 25, 2003 07:40 PM
