Toy Hauler Fuel Tank Sizes?
Received 7,104 Likes
on
on
I finally got around to measuring the fuel tank that the generator pulls from. The outside dimensions yield a 35 gallon volume. Based on that I'm going with the brochure's specification of a 30 gallon generator-specific tank. The spec of an 18 gallon tank for the toys is probably correct also.
Since the fuel gauge was on empty and only 18 gallons would go in the tank, I'm going to assume that my gauge isn't quite right and on empty I have 12 gallons left. That's going to be a lot of fun on my next outing which is scheduled to last 11 days in late fall/early winter conditions.
My toy hauler has one fuel tank for toys and generator, 35 gallons. I have a Polaris RZR XP4 1000, when I go to the desert, on average I will fill it twice = approx. 16 gallons. I have solar along with a power inverter so I very rarely use my generator. Of coarse the AC, microwave and some cloudy days will call for my generator. Fuel has never been an issue.
Toy hauler fuel tank are designed to where they will not completely fill up. It's to leave room for expansion, hot days.
My TH has a single 42 gallon tank.
The one enemy we all have with partially filled tanks is condensation. Newer traiers may be different but -- Since these are not motor vehicles, they are probably all vented to the atmosphere rather than running through some sort of vapor recovery system.
Oxygenated fuels don't keep well and if the fuel has any ethanol in it, it will suck water out of the air at an alarming rate..
And just as a reference point, I ran the Onan 5500 for 24/25 hours and it consumed approx. 1/2 gallon/per hour.....A/C cycling on and off, refrigerator running, fresh coffee in the morning, etc. YMMV.
I can't speak for all brands and/or models, but my 2017 Keystone Fuzion Impact 303 has one 30 gallon tank and there IS an evap canister that the tank vent is connected to. Last year at winterization time, I filled the tank and added the appropriate amount of Stabil to it. Fuel was fine this past spring.
Labrec01
09-14-2011 10:09 PM
rx3greenford
09-06-2002 02:03 AM
