fires, then dies
Old Jul 22, 2017 | 12:58 PM
JerzyDog's Avatar
JerzyDog
fires, then dies
The problem started the other day at a red light, went to take off and the truck dies. after a few tries it stays running and I drove home (about 3 miles). the next morning it refused to run, fires, then immediately dies, as if I'd turned off the key. thought it was the camshaft position sensor and replaced it, same situation. checked (visually) the engine wiring harness and fuel, all seems ok. I need help and/or suggestions to diagnose this problem, anybody? 1999 F250 Powerstroke
Old Jul 22, 2017 | 02:27 PM
AllaboutMPG's Avatar
AllaboutMPG
How is the oil level?
Old Jul 22, 2017 | 03:52 PM
Walleye Hunter's Avatar
Walleye Hunter
How's the fuel level? Done the Hutch mod yet? Could be clogged intake in the tank or broken foot and less than 1/4 tank.
Old Jul 23, 2017 | 10:09 AM
JerzyDog's Avatar
JerzyDog
oil level is good. fuel level is 3/4 tank. what is the Hutch mod?
Old Jul 23, 2017 | 10:39 AM
Walleye Hunter
You can search it here or google it, there's a boatload of info on it. The intake inside the fuel tank is prone to failure and it's a modification to remedy that. There is also a 'Hutch' mod that is good to do at the same time, also lots of info on it in a search.
Old Jul 24, 2017 | 12:00 PM
Karlow's Avatar
Karlow
Check the fuel pump performance. Does it maintain pressure above 50PSIG? Things that stop immediately sound electrical to me. When it fails does the WTS light come on when you try a restart? Do you have any tools? Can you measure fuel pressure? Log data?
Did you try it with the ICP disconnected?
4Wheelz
19
Mar 26, 2016 07:07 PM
willywelder
Feb 11, 2015 05:49 AM
offroadjeep
May 14, 2013 07:16 AM
patho44
Jun 22, 2012 12:38 AM
wpeloqui
S. California Chapter
Mar 28, 2008 05:39 AM
