stearing system
Old Jul 21, 2017 | 07:43 AM
hello113's Avatar
hello113
stearing system
haven't had a lot of luck on the search engine but this is the problem I'm having have a 64 f100 that some one put a Lincoln tilt steering coloum in they cut the shaft off the old gear box and welded it to the coloum junked that system put a cv ifs in it and a 302 with a c4 in the truck and have a 65 at 66 coloum that is a automatic shifter on it any one mount one of these in a truck if so can any one help with my project??? a picture or 2 would help a lot thanks mike and btw that pc 11 works pretty good on steering wheel cracks
thanks mike
Old Jul 21, 2017 | 10:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hello113
haven't had a lot of luck on the search engine but this is the problem I'm having. I have a 64 F100 that someone put a Lincoln tilt steering column in, they cut the shaft off the old gear box and welded it to the column, junked that system put a CV ifs in it and a 302 with a c4 in the truck.
I have a 65 at 66 column that is automatic shifter on it. Anyone mount one of these in a truck if so can any one help with my project.
You cannot use a 1965/66 column with an original 1961/64 gearbox.
1961/64 F100/250 2WD & F350: The steering shaft goes directly into the gearbox.
In order to remove the steering column, the Pitman Arm is disconnected from the sector shaft, then the column and gearbox is removed as a one piece assembly.
Beginning 1965 F100/250 2WD: The steering shaft has a flange made as part of it.
Since your truck has a Crown Victoria front suspension, the original 1961/64 gearbox cannot be used.
A steering coupler (rag joint) bolts to the flange, then slides onto the splines of the steering gear input shaft where it's retained by a pinch bolt.
Old Jul 21, 2017 | 12:18 PM
hello113's Avatar
hello113
NumberDummy got rid of the gearbox they ruined it when the cut it and matched and welded on it have the dd rod and all the joints needed to hook it up but I have a hole in the fire wall and need to mount my columm to the fire wall to it will work and not be a safety issue.. thanks mike
Old Jul 22, 2017 | 03:59 PM
F-ONE's Avatar
F-ONE
OK.....
So you have the Crown Victoria suspension. This suspension uses a rack and pinion. This system requires some custom fabrication to connect the steering wheel/column to the rack and pinion. This requires the use of steering u-joints.
You should be able to use the 65 up column with the rag joint and steering u-joints to mate to the rack and pinion.. It should bolt to the dash as they all do. The firewall will be a custom fix by you. Also a custom fix by you is the steering connections from the rag joint to the rack and pinion.
You'll just have to figure it out. You may need to adjust the angle of the column....maybe shorten it.......lots of things to consider with a custom install like this.
Old Jul 22, 2017 | 06:42 PM
NumberDummy
Originally Posted by F-ONE
So you have the Crown Victoria suspension. This suspension uses a rack and pinion. This system requires some custom fabrication to connect the pinion.
2003 was the first year that Crown Victoria/Grand Marquis/Town Car were available with rack & pinion steering.
JNye
Jan 24, 2019 04:03 AM
kevintoupin
16
Jun 22, 2017 04:30 PM
El Guapo 48
May 12, 2017 03:43 PM
Elcid
Apr 20, 2016 11:41 PM
Haroldmac
Jan 17, 2013 09:37 PM
