Ford 2000 E-250
Old Jul 20, 2017 | 10:08 PM
Ammar Salem's Avatar
Ammar Salem
Ford 2000 E-250
Hi hi guys I'm new to this and I would love for someone to send me some information.
I have a 2000 Econoline 250 with 234,000 miles.
I will start from the end and then I will explain to you what happened and hopefully someone can give me a good answer.
My van will not stop overheating.
I have replaced water pump fan clutch thermostat recently, my radiator last year
I can run my van idle for over an hour and it will not overheat at all. As soon as I drive within two miles my gauge shoots up too hot and I lose power and I have to stop.
I have taken it to Ford and they have told me "possible head gasket"
And that's that, but for reason I do not believe that
Someone please help
Old Jul 21, 2017 | 07:16 AM
jimbomitch's Avatar
jimbomitch
Is the fan shroud missing?
Old Jul 21, 2017 | 07:27 AM
Ammar Salem
I'm sorry I'm not very familiar with cars/vans and how they work or what they need. I have never worked on a shourd on the van. So it's the original. I hope that helps
Old Jul 21, 2017 | 08:57 PM
Wildman25's Avatar
Wildman25
The fan shroud in installed on the inboard side of the radiator, the fan blades are kind of Inside the shroud, this keeps the air flow direct in line with the fan blades.
With 234K on a 4.6? or 5.4? engine, it could be a head gasket problem, the only way to really check is with a compression check, Like this.....Link
And, yes. a bad head gasket will cause over heating with a load on the engine, IE: Driving down the road, not just parked and idle.
Old Jul 22, 2017 | 07:53 AM
Ammar Salem
Thanks very much for the answer the dealer did tell me they did a compression test and said they found air in the engine is just hard for me to except that I want to believe it's something more simple
F90E350
13
Mar 30, 2012 02:10 PM
Alter Ego
Mar 11, 2009 02:20 PM
Dannym
Aug 18, 2008 09:58 AM
gwm
Aerostar
24
Jul 12, 2008 02:55 AM
FIFTFODOKUSTOM
Jan 5, 2007 09:45 AM
