over heated now with idle issues
I have several things that need to be done to it, and one of the first ones i am doing is putting an thermal sensor controlled electric fan. something doens't seem be put in right, as the fan is too close to the stock radiator that i have recently installed. either the fan is wrong, the clutch and bell pulley is wrong, because the fan has hit the radiator once already.
anyone who knows of a good electric fan and the thermal sensor controlled unit, please let me know. would prefer the kit if they have it.
also anyone who has a good idea on what is causing the engine to idle rough, please feel free to post. i am fairly sure i will be replacing a head gasket on my return to the states from deployment, but would like confirmation before i open it up.
thanks.
You install the special radiator cap and using the hand pump, pump the pressure to around 16 psi. The pressure should hold for 24 hours. If the pressure drops, start looking for the leak.
If you do have a bad head gasket, antifreeze could be leaking into one of the cylinders so when you start the engine, the antifreeze in that cylinder is burnt off which could cause a rough idle.
If you remove the spark plugs and antifreeze is being burnt in one of the cylinders, the electrode of that spark plug will have a steam cleaned look to it.
The 300 six is a cool running engine. The factory clutch fan is adequate. No need for an electric fan. The overheating could be a internally clogged radiator, leaking water pump seal or bad clutch fan.
Not sure on the electric fan but you could check out jegs.com although I remember someone on here got a car one cheap from a breakers.
Good luck.
The electric fan that I had on my Mustang pulled a ton of juice, BUT it would cool the motor down really fast on 100* day! I only ran it in slow traffic, and at a drive thru or something. Mine was a Black Magic with an adjustable sensing unit on it... Worked like a charm, because when it was hot I could turn it down some, when it was cold I could turn it up some... Something to consider.
