1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 SRW Broken Rear Leaf packs
Old 07-18-2017, 10:19 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
2005 F-350 SRW 6.0PS Auto CCSB Camper Package. We tow heavy weekly.
Both main leaf packs broken right at the block. Go
Quote from the Stealership was $2400 to replace both packs P/L at $950 a spring pack. I complained and got them down to $1950 (dropped the leaves to $650). They did not give me a line item by line item quote. OK so I'm researching springs for this bad boy for cheaper..
I believe the truck is a code C rear end - SRW 11,400GVWR CAMPER PACKAGE.. I have the overloads and use them regularily so need them.
Here are the codes for 2005:
2 - Without Auxiliary Spring
Order By Spring Code.
6C3Z5560F $580.43
2 - With Auxiliary Spring
6C3Z5560C $623.45
2 - Dual Rear Wheel
6C3Z5560D $601.5
Has anyone found aftermarket leaf packs that come with the aux spring?
I really like the way the ride isn't terrible, but I can still haul nearly 4k lbs in the bed of this bad boy..which I do weekly. I did some reasearch and it looks like its just the same normal F-350 springs (3133lbs each) but...the overload is the key...
Looks like fordparts.com has them for $450
https://www.bluespringsfordparts.com...&siteid=214944
Parts.com has them for $430 but I dont know if they are actually OEM or not.
https://www.parts.com/index.cfm?fuse...ng-LEAF-SPRING
Here is some aftermarket stuff - but the spring rate is either lower, or way higher...
2005-2007 Ford F250SD, F350SD 2wd 4wd (Single or Dual Rear Wheels) - Leaf Spring (Rear - 4/1 Leaves) [43-1571] | $224.95 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
F250 Heavy Duty Leaf Spring F250, F350 Ford - 7 Leafs, 4400lbs. | $167.95
Can i move the ford aux leaf over os what else needs to be replaced? Can I replace the packs and thats it - or do I need to also do Ubolts etc?
Thanks for the help fellas - I'm trying to to this the right way...but...cheaper...lol
Old 07-18-2017, 11:52 PM
Tofan's Avatar
Tofan
Tofan is offline
6C3Z5560F $580.43
6C3Z5560C $623.45
2 - Dual Rear Wheel
6C3Z5560D $601.5
White Bear Lake Ford parts has 6C3Z5560C for $411.48 and 6C3Z5560F for $383.09. White Bear Lake Ford only charges 10% over what it costs them to buy the part from Ford, so very rarely will they be beaten with price. I would use them and if you need help, give them a call and ask for a guy named Pat!
Old 07-19-2017, 06:15 AM
redford's Avatar
redford
redford is offline
Received 1,582 Likes on 922 Posts
Find your local spring shop and give them a call. You might be very surprised what a set of custom leaf springs will cost.
Old 07-19-2017, 06:31 AM
ATS Junior's Avatar
ATS Junior
ATS Junior is online now
SPONSOR
Send me a message or give me a call. Those prices are extremely high, I should be able to help you out.
-Junior
Old 07-19-2017, 09:37 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
Thanks all for the notes:
I'm doing additional research, and it appears that the the spring rate for the F-350 is roughly 3133lbs per this: (page 27)
https://www.fleet.ford.com/truckbbas...essd-exlbb.pdf
This roughly matches the ATS and SDtrucksprings.com packs (3000lbs)....
Ford F250 SuperDuty 2wd,4wd Truck Leaf Spring, Ford F350 SuperDuty 2wd,4wd Truck Leaf Spring, Rear
So the question is...can I just replace the main pack and keep using my auxiliary? If so, I'm basically where i want to be, though running 3000lbs springs instead of the 3133lbs springs... I'm a little concerned about losing those 266lbs. We run real close to RAWR...
Old 07-19-2017, 10:10 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
Check this out...lists the aux spring separately:
F81Z-5588-DA
and then the pack:
6C3Z-5560-D
REAR SUSPENSION for 2005 Ford F-350 Super Duty
Old 07-19-2017, 10:22 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Call and talk to junior at ATS
You can reuse your overload spring.
Old 07-25-2017, 07:13 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
Thanks for all the help guys - I'm halfway across the country from my garage and tools, and with no mailing address - so online order wasn't going to cut it.
I talked to a different Ford dealer in the area and they recommended a local spring shop. Woodwards Springs in Brockton, Massachusetts. They were excellent. It was a working man's shop (8 bays and mostly Semi's) so not a place I'd take the lady LOL. BUT this place was top notch. They had me in next day in the am and had it done in 2 hours (charged me 3hrs labor but oh well). They advised against going with dually springs due to ride, and replaced my leafs with 43-1261 springs at $168 each, plus all new hardware. They simply re-used the Ford factory auxilary or overload springs I was so concerned about. So it looks like the camper package is the standard springs PLUS that auxiliary bolted to the top, which is reusable.
$760 out the door with the leafs, bolt kits and labor. The 43-1261 leafs are rated for 3000lbs, it seems, regardless of brand.
Hooked up the trailer yesterday and looked like it always does - and rode just fine.
/done
Thanks guys
Old 07-25-2017, 08:18 PM
redford's Avatar
redford
redford is offline
Awesome. Sounds like a great shop.
VaFordman26
11-09-2017 06:30 AM
Daewoo
08-22-2016 10:09 PM
carl2591
06-14-2015 06:03 AM
02expy
07-14-2014 10:53 PM
venom_99
05-06-2006 08:01 AM
Quick Reply: 2005 SRW Broken Rear Leaf packs
