57 F500 rear axle seal
After checking some of the cross referencing not all the ones listed will be suitable
So you will have to look closely at them some listed are single lip seals not suitable for an axle seal like National 416297 .
That interchange are just ones with the same ID and OD some are flat faced like Victor/NAPA 64561 and others are off set like Victor SS64564
You may have to pull a seal to match it up with the correct style.
I could not get the timken number ND supplied to match up to any thing. But there is a A1205G735 number that Meritor and Rockwell uses that crosses over, maybe a typo in the book ?
I would just get the stemco one and you should be safe.
Original leather type seals
National 5751 At least according to the pic on the O Reily's web site double check that it is.
Modern Rubber type seals
Stemco 392-9038
National 370046A
Victor/NAPA 64561
Victor SS64564
Stemco 392-9038
National 370046A
Victor/NAPA 64561
Victor SS64564
Did you ever find the correct rear axle seal? I have the same problem. Used National 416297 seal. It fits but leaks. emailed Timken and they recommended National 455858. too big. Not 3.125 shaft size. Now they say National 370046A as an alternate. It looks like it might have more than one seal lip. Did you get it figured out?
Roger
Roger
Axle seals are looked up in Ford truck parts catalogs by the size of the rear brake shoes.
If there's more than one brake size (there isn't on yours), then one needs the weight capacity of the rear axle.
B6J-1175-A .. Axle Seal / Timken part #: A-1205-G-736 / Obsolete
Applications that apply: 1957/60 F500 with 15" x 4.00" rear brakes.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
COURTESY AUTO & TRUCK in Thorpe WI has 2 = 715-669-5519.
FREESE MOTORS in Monticello IA has 7 = 319-465-3541.
MILLER OBSOLETE PARTS in Binghamton NY has 7 = 607-722-5371.
NOS PARTS LTD in Waxahachie TX has 10 = 972-937-2201.
FYI: Two single speed rear axles were available for 1957/60 F500's: Timken C100 (11,000 lbs. capacity) & Timken D100 (13,000 lbs. capacity).
1957/60: AXLE code 22 decodes to 6.20-1 and that's it! I had to look in the application charts for F500 rear axle availability with 6.20-1 (listed above).
Stemco 392-9038
National 370046A
Victor/NAPA 64561
Victor SS64564
Stemco 392-9038
National 370046A
Victor/NAPA 64561
Victor SS64564
jdemaris
08-15-2015 10:57 AM
rchalmers3
Large Truck
04-15-2015 08:43 AM
