TTB Suspension - Steering problems
Old Jul 20, 2017 | 01:44 PM
Franklin2's Avatar
Franklin2
You can see from the printout you are out of spec on your caster and camber. Any number that is red is bad. You can see all they did was adjust the toe-in, which is very simple and easy to do.
To adjust the caster and camber on these trucks is a real pain. The upper balljoint has to be busted loose on both sides, and the eceentric has to be turned, trying to get the caster and camber in with one adjustment. And if they can't get it in, they have to buy a new eccentric and put it in to give them more adjustment. Expect to pay at least $150 for one of these alignments, and that does not include the cost of the eccentric bushings.
Some of the other guys may know more about those specs, but I am suspicious that you have changed front or rear springs, have a spacer under the front springs, or air shocks or something in the rear. Is this truck's suspension totally stock?
Old Jul 20, 2017 | 01:47 PM
CountryBumkin's Avatar
CountryBumkin
It looks like there are about 2 degrees difference in the Caster between the right and left wheels. That would cause a pull to the right. Why didn't the alignment shop deal with this? You can see it is out of spec (red text color).
I would be looking for an alignment bushing to add Caster to the right wheel.
Did the alignment shop check the radius arm bushings for wear?
Old Jul 20, 2017 | 01:56 PM
reamer's Avatar
reamer
I had to do this and the only way to get the ball joints to "tiit back" (forget which it is, caster or camber) was radius drop down brackets, the only way to get the tires to sit vertical were drop down axle pivot bushings....
Old Jul 20, 2017 | 02:01 PM
Franklin2's Avatar
Franklin2
If you have it lifted in any way, that is true. If it's totally stock, or only lifted a inch or so, then the eccentrics should bring it back in.
Also if it's lifted and still has the stock pitman arm, that will cause bump steer, the truck will want to dart one way or the other when you hit a dip or a bump in the road.
Old Jul 22, 2017 | 12:39 PM
yardbird's Avatar
yardbird
If not changed yet, go ahead and do the axle pivot bushings and radius arm bushings. It made a world of difference on my truck, and neither of those bushings looked worn very much, or even had any rubber cracking.
It sure brought my caster back to where it should be.
RenoHuskerDu
22
May 31, 2019 11:54 AM
Rachel Moody
15
Jan 16, 2017 11:51 AM
IrishMike
Nov 29, 2016 05:23 PM
midsouth
Apr 6, 2012 07:01 PM
jdharris5
1997 - 2003 F150
Feb 19, 2003 09:27 AM
