Block Numbers
Old Jul 17, 2017 | 11:43 PM
coltonoslund's Avatar
coltonoslund
Block Numbers
On my 78 F250 400 , it looks like the numbers on the block are 7C3O andmd D7TE-A3B. My question is, does this number mean that the original block was replaced? Or, did the factory put 77 blocks in 78 model year pickups. I may be over thinking this.
Thanks.
Old Jul 17, 2017 | 11:53 PM
85e150's Avatar
85e150
March 30 '77. I've read here that they let the blocks sit for a while after casting. If that is the case here, then your March block would have been about right for an early production '78.
D7TE is the revision date for the casting and appears to have carried on to the end of 400 production if I am reading this right:
Kelly hotrod - Ford Engines Page 2
Nothing to worry about.
Old Jul 18, 2017 | 06:22 AM
somethingclever's Avatar
somethingclever
It is the engineering revision number for the block mold.
THey were not changed every year to match production.
It's normal.
Old Jul 18, 2017 | 11:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by coltonoslund
On my 78 F250 400 , it looks like the numbers on the block are 7C30 and D7TE-A3B
D7TE-A3B = Block casting number for 351M/400: 1977/79 F100/350 & 1978/79 Bronco.
7C30 = Block cast March (C) 30, 1977 (7).
Once the block was cast, it sat outside to 'season' then was shipped to the engine assembly plant to be finished, then was sent to an assembly plant to be installed in a vehicle.
This process could take between 6 months to a year.
Buldog
25
Feb 26, 2019 05:04 PM
hail destroyer
Oct 27, 2018 03:12 PM
jerm111
Dec 11, 2009 11:05 PM
smokeyb97
May 15, 2009 01:01 AM
jb85302
Nov 1, 2000 04:30 PM
