Quench distance
Old Sep 7, 2003 | 09:26 PM
GT40man's Avatar
GT40man
Quench distance
take that to either kb or as engine shop
Old Sep 7, 2003 | 11:58 PM
Brian S's Avatar
Brian S
Quench distance
Yeah, the KB site has been down quite a while, but 99% sure from my notes.
UEM-KB148 STD, .020, .030, .040, .060 3.500 5.778 13cc Dish .912 $215.00
Keith Black #148 pistons - reverse dome, 1-relief, 13cc, 1.67 CH.
If you really want forged pistons you may have to go a different way.
10.3
-2
-6.58
-1.67
.050 DC
-*** offset?
-*** decking?
I'm not sure why you want to use the 400 pin.
You may have a hard time finding a machinist willing to offset bore the piston.
At least that was mentioned in a previous post.
Which aluminum heads again?
I can probably do a set of rods for you. Ask me about the details on my forum.
http://autos.groups.yahoo.com/group/...1Boss351HO400/ or
www.yahoogroups.com Keyword "351C"
Old Sep 8, 2003 | 06:28 AM
danlee's Avatar
danlee
Quench distance
The heads are Austrailian 3V Aluminum heads. The web site is
www.chiheads.com
Old Sep 8, 2003 | 09:33 AM
Brian S's Avatar
Brian S
Quench distance
Yes, I'm familiar. Those are some kick-*** heads but a little pricey for an average rebuild. I posted a bunch of picks on my forum. There are a couple other heads to consider, I'll talk with you on my Yahoo forum.
Old Sep 8, 2003 | 08:15 PM
danlee's Avatar
danlee
Quench distance
I found a program to calculate Dynamic Compression. If I put in 64cc heads, 0.040 gasket, 0.0 deck height, flattop piston and use my intake valve closing at 72 degrees ADBC, I get a effective stroke length of 2.899" and dynamic compression = 9.2:1.
9.2 x 14.7 = 135.24 lbs of cylinder pressure
I think the quench should be quite effective with this dynamic CR.
Old Sep 8, 2003 | 09:14 PM
Brian S's Avatar
Brian S
Quench distance
Was that online somewhere or can you break down the numbers you have to use?
Old Sep 9, 2003 | 06:02 AM
danlee's Avatar
danlee
Quench distance
I downloaded a program for Dynamic Compression that I got from this website.
http://cochise.uia.net/pkelley2/DynamicCR.html
I ran it using a 4" stroke, a 64cc head and flattop piston, Zero deck height and an intake valve closing of 72 degrees ABDC. It gave me an effective stroke of 2.899". I ran that through my CR calculator and came up with 9.2:1 as the Dynamic Compresion ratio(DCR). The Static Compression Ratio(SCR) for these specs is 12.5:1.
Reading the explantion at the website, I find that 8.5:1 is maximum DCR for a street motor on 92 Octane.
All this is telling me that I must reduce my SCR in order to reduce the DCR to 8.5:1, or get a longer duration cam.
Now I can dish the piston or change cams to get that reduction.
Old Sep 11, 2003 | 09:43 PM
GT40man's Avatar
GT40man
Quench distance
nice
BigBlocker0248
Jul 7, 2016 10:06 AM
lizardman1
Mar 14, 2014 02:43 AM
ColodadoFordBoys
Jan 22, 2009 12:05 PM
broncman
Aug 4, 2006 01:57 PM
dc600slayer
Nov 5, 2004 10:23 AM
