Difference been normal ac and max ac setting?
Old Jul 17, 2017 | 12:35 PM
bluefeather300's Avatar
bluefeather300
97 cc drw zf5
I assumed max was recirculation but I see, hear, feel no difference switching to max. And to tell the truth it seems that it may actually be cooler in normal ac mode.
any information anyone can give on this subject?
Old Jul 17, 2017 | 12:37 PM
knottyrope's Avatar
knottyrope
fresh air on norm or recirculate on max
Old Jul 17, 2017 | 12:49 PM
madpogue's Avatar
madpogue
^^^^^ +1; pop the hood and look near the passenger side firewall. You'll see a vacuum actuator/motor/whateveryacallit; IIRC that's the one for recirc/max. And it's REAL common for that hard-ish plastic vacuum line to get brittle and break. So inspect that line.
Old Jul 17, 2017 | 01:28 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Yep. There should be a tiny white vac line coming out of the harness next to the passenger hood hinge. Mine had rotted away a long time ago, so I took a piece of 1/8" fuel/vac line and shoved it over the old white line, and then onto the actuator. I bought a 12" piece and it was the perfect length.
Old Jul 19, 2017 | 06:59 AM
oldbird1965's Avatar
oldbird1965
x2 on both #3 & #4 replies. I did the repair and now don't have to breath as much road fumes!
Old Jul 19, 2017 | 12:14 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
And you can make the A/C mod
https://www.ford-trucks.com/forums/1...hroud-mod.html (post #4)
This is a good read for you:
https://www.ford-trucks.com/forums/1...at-a-loss.html
benbuilder
Trading Feedback
Aug 22, 2016 07:08 AM
chetty_mo
Sep 14, 2011 08:48 AM
CraigK
24
Aug 8, 2010 07:43 PM
currituckF150
May 21, 2007 03:51 PM
gotdiesel
Aug 4, 2004 09:47 PM
