good morning ! ordered some new core support rubbers and bolts but on my core support I have to weld in some support plates the holes in them are a little bigger than 1 inch need to know the size of the holes that are supposed to be in the core?? also it is a 64 f100 it had the square rubbers in it they wore about 1/2 the metal away the support metal.. thanks mike
have a good day!
hello.....I happen to have my front CLIP off getting ready to pull the motor. The core hole is just over sized for the rubber insulator to fit into, which is 1 ". The core support hole measured 1 1/8".
Hammy
Reason: TYPO ERROR
thank you hammy ! just finished welding new plates in with 1/4 holes in them will take a unibit and take them out to 1 1/8
u folks are great on the forums mike
hello.....I happen to have my front **** off getting ready to pull the motor. The core hole is just over sized for the rubber insulator to fit into, which is 1 ". The core support hole measured 1 1/8".
Hammy
Really? That sounds painful and more a problem a woman would have - maybe?
