Random dying issue help
Old Jul 14, 2017 | 10:07 PM
1984_IH6.9_Project's Avatar
1984_IH6.9_Project
Hi, I have a 1984 Ford F-250 with a 6.9L and yesterday I drove it to work and it did fine. But on my way back home every time I would slow down for a red light or stop sign until I got out of town it would die and I would have to start it again. Or when I was pulling away from being stopped in first it would try and die if I eased into it I had to ease off the clutch and smash the accelerator down to keep it running. Does anyone know what might be happening or how to fix it?
thanks for any help
Old Jul 14, 2017 | 11:31 PM
Macrobb's Avatar
Macrobb
Fuel issues... sounds like you are running out of fuel.
Were you around 1/4 tank? The fuel pickups like to fail after this many years.
Also, it might be a good time to replace the lift pump on the side of the block; cheap and can't hurt.
Old Jul 15, 2017 | 02:00 PM
1984_IH6.9_Project
I was at 1/2 a tank but by the time I was home I was at almost a 1/4 only because trying to get going from stopped it smoked a lot since I couldn't ease into it without it dying
Old Jul 16, 2017 | 04:56 AM
hturner12's Avatar
hturner12
Fuel leak?
Old Jul 17, 2017 | 10:01 AM
1984_IH6.9_Project
Originally Posted by hturner12
Fuel leak?
It's not leaking any fuel
Old Jul 17, 2017 | 05:43 PM
1984_IH6.9_Project
I switched to my second tank and there's no issue so I'm taking that as it has to be something with the front tank
Old Jul 17, 2017 | 09:58 PM
Macrobb's Avatar
Macrobb
You need a new fuel pickup most likely. $30 off ebay.
The hard part is getting to the top of the tank; either drop the tank or pull the bed.
Old Jul 18, 2017 | 12:31 AM
1984_IH6.9_Project
annoying part is I just put the bed back on but depending on how flexible the part is I have about 6 inches between the top of the tank and the bottom of my flatbed
Old Jul 18, 2017 | 01:28 AM
Squarebodyking's Avatar
Squarebodyking
I have a 85 F-250 with the 6.9 and it did the same thing. I ended up taking the tank of and found the the fuel pick screen had pretty much just fell apart. I bought on on amazon for around 25 bucks. Been looking to go ahead and do the same to my rear tank and i found that LMC Truck had the best buy on the part. Here is the link to the part if it helps. Truck Parts and Truck Accessories
P.S. Its part #14
Old Jul 18, 2017 | 04:25 AM
hturner12's Avatar
hturner12
Amazon or ebay also
bigcountry1009
Nov 12, 2014 11:09 AM
esley
Sep 8, 2012 07:56 AM
allis327
Feb 17, 2012 09:46 PM
jim dog
Georgia Chapter
Nov 17, 2002 08:03 PM
