Anyone using FORScan for Windows?
I was getting 168 ma reading until I pulled the 50A fuse #22 in the under hood box then the meter dropped to 21ma.
Now I need to find a schematic for that circuit and start the troubleshooting.
So I placed the fuse back in the panel under the hood and began pulling fuses inside.
The culprit is #15, a 5A fuse that protects the: Stop Lamp Switch (logic), Generic Electronic Module (GEM), Powertrain Control Module (PCM), Four Wheel Anti-lock Brake System (4WABS) Module, Brake Shift Interlock, Cluster and PCM Keep Alive Memory.
Not sure but it sounds like the most expensive circuit in the truck but then I could just be paranoid. LOL
I am going to hook everything back up and take the truck for a drive. When I get back I will pull the codes with FORscan and hop I get some kind of indicator as to where to look.
You are going to have to isolate those devices one by one to see which is the problem as you have been doing to get this far. You are doing well, in a short amount of time. Keep it up!
There must be a diagram or photo somewhere on here but no luck finding it so far. Maybe I am using the wrong words in my searches? Kinda like using the word parasitic when hunting down information. I kept trying battery drain or draw down and got tons of stuff that didn't help.
===OBDII DTC P0670-C===
Code: P0670 - Glow Plug Module Control Circuit
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
This DTC may be caused by :
Open circuit.
Short circuit
Possible causes are:
Harness wiring
GPCM
PCM
===END OBDII DTC P0670-C===
===OBDII DTC P1690-P===
Code: P1690 - Wastegate Solenoid Circuit
Status:
- Pending - malfunction is expected to be confirmed
Follow the routines in the service manual to resolve the DTC listed.
===END OBDII DTC P1690-P===
===PCM DTC P1690===
Module: Powertrain Control Module
===END PCM DTC P1690===
===PCM DTC P1000===
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
Check of all systems is not complete since last memory clear.
--Possible Causes--
- The vehicle is new from the factory and has not yet been through a complete OBD Drive Cycle.
- The battery or PCM has been disconnected.
- An OBD monitor failure had occurred prior to completion of an OBD Drive Cycle.
- The PCM DTCs have been cleared as part of a service process.
Note: The only way P1000 can be cleared (removed) from memory is when all of the OBD monitors have been successfully completed during normal vehicle operation.
P1000 cannot be cleared from the PCM when: 1. The thermostat is stuck open and a DTC is not generated. 2. There is an open VSS circuit and a DTC is not generated. 3. If the vehicle has a Power Take Off (PTO), the circuit is shorted to VPWR or B+, or the PTO is ON during Self-test.
The purpose of the Diagnostic Trouble Code DTC P1000 is to indicate that not all of the On Board Diagnostics OBD monitors have yet been successfully completed. You may also refer to the OBD Drive Cycle defined under the Powertrain Control/Emission Diagnosis Manual-Diagnostic Methods or the Owner's Manual.
Remember: It is not necessary to remove P1000 from the Powertrain Control Module PCM by driving the vehicle.
===END PCM DTC P1000===
===PCM DTC P0230===
Code: P0230 - Fuel pump primary circuit malfunction
Fuel pump primary circuit malfunction.
Open or grounded fuel pump primary circuit.
Relay
Improper connection
fuel pump relay short circuit to positive
Fuel pump open circuit
No live feed to the fuel pump relay
Faulty or damaged PCM.
===END PCM DTC P0230===
===PCM DTC P1662===
Code: P1662 - Injector Driver Module Failure
===END PCM DTC P1662===
===PCM DTC P0640===
Code: P0640 - Manifold Intake Air Heater Control Circuit Fault
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
Inspect connectors for signs of damage, water ingress, corrosion, etc.
===END PCM DTC P0640===
===PCM DTC P0670===
Open circuit.
Short circuit
Harness wiring
GPCM
PCM
===END PCM DTC P0670===
===ECS DTC B1869===
Code: B1869 - Lamp Air Bag Warning Indicator circuit failure
Module: Electronic Crash Sensor
===END ECS DTC B1869===
===GEM DTC None===
Successful DTC reading, no error codes found
Module: Generic Electronic Module
===END GEM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
Being a beginner at all this stuff my take is this: Good News: no faults in GEM or ABS Bad News: I may have spent $300 dollars on the glow plugs and GPCM for nothing. The Wastegate Circuit problem is leading me to the PCM since I have traced the wiring all the way to the main harness before the plug.
Maybe one of you with more experience in this could review the list and see a common denominator or something the might more closely pinpoint the problem(s)?
IDM - will not run
Air bag warning - truck will run
GPCM - May only effect cold starts like a failing GPR, but not sure
Air intake heater - truck will run
Fuel pump - truck will not run
Are all of these related somehow, I have no idea. Hopefully someone will be along shortly to provide some better advice.
Sorry I could not be of more assistance and I understand electrical problems can be a pain in the *** at times. I work in the IT field and the gremlins seem to spawn from wires and machines at times...
Today I tore the dash a part hoping to find the culprit connector or component.
Checked everything listed and even checked with the PCM disconnected, then the dash completely unplugged and still 170 mA draw.
Decided to pull the upper gray plug on the GEM and viola the meter dropped to 22 mA. Plugged it back in and meter jumped to 170 mA.
Left it plugged in and removed the lower (smaller) gray plug and the meter dropped 86 mA and when plugged back in the meter was again at 170 mA.
Can anyone tell me what to do next?
Now I am back to the PCM and the Codes that won't go away.
Here is the reading from the FORScan PCM Module self test with KOER:
(OK) [12:22:52.683] Key On Engine Running On Demand Self-Test has been started
(WARN) [12:24:11.359] Test completed, found DTCs: P0476, P0640, P0670
===DTC P0476===
Code: P0476 - Exhaust pressure control valve malfunction
Exhaust pressure control valve performance.
--Possible Causes--
- Stuck or damaged butterfly.
- Misadjusted or damaged linkage.
- Restricted Exhaust.
- Exhaust leaks.
- Exhaust Pressure Regulator (EPR) valve.
- Exhaust Back Pressure sensor.
- Damaged PCM.
===END DTC P0476===
===DTC P0640===
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
===END DTC P0640===
===DTC P0670===
Open circuit.
Short circuit
Harness wiring
GPCM
PCM
===END DTC P0670===
