Are rear cab bushings same from std cab to super cab?
on
If you're going from rear of cab to front of cab, then no they won't fit properly. If you're going from rear of cab or rear of cab, then yes, they will fit.
The front rubber mounts are shorter than the rear rubber mounts - they shouldn't be swapped because they'll mess with all your body lines and hardware connections at the firewall with the added height.
Originally Posted by hail destroyer
I've got two brand new bushing/rubber mounts (Ford: absorber) for a Standard Cab that I'd like to install on my Super Cab. Are they the same?
1973/79 F100/350 Regular/Crew Cab; 1974/79 F100/350 Super Cab:
Genuine Ford parts.
D3TZ-1000396-C .. Upper Front Cab Absorber/Retainer / Obsolete
D3TZ-1000155-B .. Lower Front Cab Absorber / 2 9/32" O.D. x 31/32" I.D. x 7/8" thick / Obsolete
D3TZ-1000396-B .. Upper Rear Cab Absorber/Retainer / Obsolete
D3TZ-1000155-A .. Lower Rear Cab Absorber / 2 5/8" O.D. x 15/16" I.D. x 1 3/8" thick / Obsolete
Originally Posted by 74f100sc
rear same, front same- all same...uppers/lowers (of same mount) different both front and rear.
Front is different than rear. Front upper is different than front lower. Rear upper is different than rear lower.
Genuine Ford parts.
Genuine Ford parts.
ThatOneGuyWithThe79
10-21-2011 08:02 PM
davbell22602
21
09-06-2010 11:08 AM
