e99 hub swap ?
Old Jul 11, 2017 | 08:20 PM
lostfish's Avatar
lostfish
e99 hub swap ?
I'm due for brakes/rotors and hubs, so I'm upgrading to the L99+ setup. Does anyone know if I can use my stock locking hubs and swap them over to the new Timken hub assembly? I'd love to get some nice Warns or something like that but that will need to wait until the budget allows. Thanks yall.
Old Jul 12, 2017 | 08:14 PM
jhl3's Avatar
jhl3
Yes, the stock ESOF locking hubs are compatible.
The rotors for the L99 have a different offset that will match the offset for the L99 Hub unit bearing.
Old Jul 12, 2017 | 08:42 PM
DieselDenny's Avatar
DieselDenny
Ohhhhhh do I dare,
Hubs are good, but you should be aware that you will not be able to use anything E99 from this point. (if you upgrade) Calipers same.
Flange differences are different depth and you can throw everything away or put them on the free list regarding rotors and brackets. Otherwise you have a locker or a dragger.
All else plays well.
Hope it goes well. (I would also replace the rub lines to stainless braided as long as I was drunk)
Denny
Old Jul 13, 2017 | 05:10 PM
jhl3's Avatar
jhl3
Originally Posted by DieselDenny
Ohhhhhh do I dare,
Denny
You are stating that the caliper mounting bracket is the same, correct?
X2 on the stainless lines.
Old Jul 14, 2017 | 01:13 PM
lostfish's Avatar
lostfish
From the threads I've come across, it seems the E99 caliper assemblies are compatible with the L99 setup, and only the hub unit and rotors need to be swapped. Good idea on the stainless, gives me an excuse to get drunk
Old Jul 19, 2017 | 02:01 PM
bleeds blue's Avatar
bleeds blue
I did this just a month ago. They only thing you need to change is the hub and rotor. EVERYTHING else from the E99 will work.
Old Jul 20, 2017 | 01:39 PM
lostfish's Avatar
lostfish
Thanks Blue!
Old Oct 8, 2017 | 02:18 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Any recommendation on specific parts and/or suppliers? I need brakes and figured it would be the perfect time to swap over to the L99 setup and make life easier (cheaper?) down the road. Thanks!!!
Old Oct 8, 2017 | 06:37 PM
Firefighter 1406's Avatar
Firefighter 1406
I personally go with Autozone Duralast Gold rotors, comes with a 3 year warranty. Warp
Or whatever take them back no questions asked. And I run there ceramic pads which also are lifetime. Never buy another set of pads again.
Old Oct 8, 2017 | 07:18 PM
DieselDenny
Great call. I'm on that!
Thanx amigo!
Denny
Old Oct 9, 2017 | 09:10 AM
BBslider001's Avatar
BBslider001
Yup, same here...what he said. You an check my thread out and see what all it entails. It's a pretty simple job really.
Old Oct 9, 2017 | 11:22 AM
papadelogan
Mind posting a link when you get a minute? Thanks!!
Old Oct 15, 2017 | 04:08 PM
DieselDenny
I have a limping hub and I'm going full in on both sides with the conversion to L 99 up.
Rotors and hubs are on the way.
Hopefully the stub survived but it's doubtful. Started to hear a chirp and a slight drag on the drivers.
Great post and you save tons of cash converting.
Thanx fellas!!!!
Denny
Old Oct 15, 2017 | 08:51 PM
BBslider001
Man, sorry about that....just saw this. Here ya go!
https://www.ford-trucks.com/forums/1...b-for-ike.html
Old Feb 24, 2019 | 02:01 PM
papadelogan
Bumping an old thread, but I'd rather do this than start a new thread for an old topic... anyways...
Looks like it's no longer cheaper to swap up to the L99 Hubs. Right now off RockAuto, the Timken E99 hubs are $100.89 and the Timken L99 hubs are $184.89 each. Unless brake rotors offset a large part of the $168 difference to do both sides, I guess I'll be sticking with the old style parts. If it were only $5 or $10 per, I'd do it... but $168... I'll keep that cash.
