AC Actuator part number
Old Jul 11, 2017 | 05:34 PM
Glenn54's Avatar
Glenn54
I need to replace the AC Actuator (the one the small hard plastic white hose connects to) that is located on the left side of the firewall. Does anyone have a part number for this? Thanks. 95 F150 5.0 L
Old Jul 11, 2017 | 11:56 PM
Torky2's Avatar
Torky2
Go to rockauto, put in your truck info, then look at:
Heat & Air Conditioning --> Heater Blend Door Actuator
Then click on the blue "Info" button. They are listing it as a "Blend Door Actuator" (Wrong!), but Motorcraft correctly ID's it as HVAC Recirculation Door Actuator (Vacuum), which it is.
By clicking on the Motorcraft Part number in blue, you can see what trucks vs. years it was used on. I was surprised my 1994 Bronco wasn't on the list, so I looked it up for 1994, the part # changes from 1994 to 1995, seems 1994 has a curved vacuum port, 1995 is straight. I assume (but don't know!) that the mounting and lever are the same for the years.
Anyway, there's the Motorcraft part #, YH1463
Old Jul 12, 2017 | 01:19 AM
GuitarJesus's Avatar
GuitarJesus
it sucks that the only actuator still available is the vacuum motor in the engine compartment. The others are obsolete.
Old Jul 12, 2017 | 02:25 AM
Glenn54's Avatar
Glenn54
Thanks guys.
Old Jul 12, 2017 | 09:17 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That's good to know. I think I have one behind the dash going bad. I'll have to start checking the junkyard.
Old Jul 16, 2017 | 06:11 PM
Glenn54's Avatar
Glenn54
Thanks again Torky2. Part ordered. We'll see if that solves the problem.
Vinford
Jun 6, 2015 09:20 AM
k9dr
Feb 6, 2015 01:15 PM
jessibrown
1983 - 2012 Ranger & B-Series
32
Sep 25, 2011 08:21 AM
skierbri10
Feb 15, 2010 02:39 AM
Franzh
Sep 1, 2004 09:00 PM
