Hot hardstart NIGHTMARE!!
Old Jul 10, 2017 | 08:07 PM
HomerCamper's Avatar
HomerCamper
1982 ford e150 vanK, all new!! New crate motor less than 1k new dizzy upgrade Ford 302 with motorcraft 2150 just had professionally rebuilt. Here my issue, first thing in morning one pump of gas and fires up beautifully! After engine is up to running temp, turn off and if I start it again immediately it fires up nice, wait 1min to and hour and it acts like it's flooded and I have to foot to floor while cranking and it finally starts up but all crappy and blows a bit of black smoke out the pipe, after that runs great, messed with choke housing rich-lean lean-rich in between and same thing. What am I'm missing, this is after the carb rebuild and just installed it back on motor today.. help!
Old Jul 10, 2017 | 09:33 PM
EagleFreek's Avatar
EagleFreek
It's probably the crappy ethanol fuel boiling out of the float bowl and flooding the carb. I installed a 2150 on my Eagle I used to have and it would do the same exact thing. Maybe try using non ethanol fuel and see if it still does it. A heat shield may need to be installed under the carb.
Old Jul 11, 2017 | 09:09 AM
HomerCamper
All I ever put in is non ethanol 91, wrapped fuel line, and heat shield under carb.. should of mentioned that..
Coletrain816
Aug 10, 2019 04:15 PM
nolszewski
Jul 2, 2018 08:39 AM
FoMoCo13
13
Nov 13, 2016 08:59 PM
lilsmokey
24
Oct 26, 2012 11:07 AM
steve62
Jun 6, 2002 01:45 PM
