Spacer?
Old Jul 10, 2017 | 05:57 PM
mustang81's Avatar
mustang81
Spacer?
I just bought a 1979 f250 ranger xlt. The previous owner install 3" lift and now my shafts look too short. What can i do ? Spacer ?
Also what is the name of the front bar with with a tie rod end to streering ?
Old Jul 10, 2017 | 08:41 PM
tabascom16's Avatar
tabascom16
Only thing you can do for too short a driveshaft is get it lengthened. 3" lift shouldn't cause that though.
The drag link? Not quite sure from your description.
Old Jul 28, 2017 | 07:41 PM
mustang81's Avatar
mustang81
Signal flasher relay
I just bought a 1979 f250 ranger xlt 4x4 auto and the flasher are ont working. Did the flasher have 2 or 3 connerctor ?
Old Jul 29, 2017 | 02:20 AM
1TonBasecamp's Avatar
1TonBasecamp
What tbascom (Tully?) said. If you mean the link from the steering box and pitman arm, down to the tie-rod, then that's called the draglink.
On 4wd trucks, there is a link parallel to that one mounted between the frame and axle, called the trackbar.
Agree too that (normally) a 3" lift won't necessitate longer shafts. Even on short-wheelbase Broncos they don't need longer shafts for 3" of lift on 95% of them.
Of course, even with the same odds you could be one of the unlucky 5%!
One factor in that is rear pinion angle. If the block has a taper and they installed it backwards (thick section forward, thin to the rear) the pinion will point down more and create a mistaken need for a longer shaft, when in reality you need to raise the pinion to correct the angle.
So, is this '79 a two, or four-wheel drive? Standard cab, Super-Cab, or Crew-Cab? Not many of the latter around, but they exist. This could change the answers for the rear shaft.
Is the rear driveshaft the usual single-cardan style (one u-joint at each end) or the double-cardan style with the CV yoke at the top near the transfer case?
Those answers and maybe even a couple of pics would be great.
Paul
Old Jul 29, 2017 | 06:19 AM
good to doo's Avatar
good to doo
You can,t lengthen a drive shaft. You get a new 1
Old Jul 29, 2017 | 12:05 PM
tabascom16's Avatar
tabascom16
I have had several lengthened. They cut your ends off and weld them on new tube.
ProjectDually
1983 - 2012 Ranger & B-Series
Jan 4, 2015 07:41 AM
robhowardiii
Offroad & 4x4
32
Dec 1, 2012 08:14 PM
muddmonky
May 16, 2011 09:02 AM
1979meangreen
Dec 4, 2004 12:53 AM
HIROLLN
Dec 10, 2002 01:25 PM
