Intermittent Starting Issues
Whenever I fill the truck with gas I have trouble getting it to start. Most times the first attempt will almost immediately stutter and kick off. Then on the second try it takes a few seconds of turning over before it catches, then will stutter for another second or so before actually starting and idling. Best comparison I can give is that its similar to when you'd try and start an old carbed engine after letting it sit for a little while. You have to let it turn over for a couple seconds, then give it some gas. Its never failed to start on the second try, but its still a tad disconcerting.
I'm inclined to think it may have something to do with the capless fuel filler cap. This is the second vehicle I've had with one, but the other was a Fusion that was brand new, so of course it didn't have any issues. There are no CELs up, and it runs great otherwise. Should I be worried and should I look into getting something looked at?
