Modular V10 (6.8l)
00 X 1st start issues ??
Old Oct 30, 2015 | 07:04 AM
harley4jcs's Avatar
harley4jcs
I've got a 2000 X 6.8 that is just being used around the house. I keep it up so it's not deemed "sitting" BUT it's not seeing more than 100 miles a month either. The 1st start has been producing some strange issue. The engine will start, fall off, rev up, then die. Restart is fine & any other starts that day are fine. Truck runs like a top otherwise. This issue is getting progressively worse SO I'm trying to get ahead of it. ANY IDEAS ??? Thanks
Old Oct 30, 2015 | 07:17 AM
projectSHO89's Avatar
projectSHO89
Probably fuel pressure leak-down. Cycle the key from OFF to RUN, pause two seconds, then OFF again. Repeat once more and then see if the engine starts reliably.
Old Oct 30, 2015 | 11:46 AM
harley4jcs's Avatar
harley4jcs
Will Do... Thanks for the tip. If this corrects the issue is there anything to worry about or is this just an issue of a 16 Y/O non-daily driver ??
Old Oct 31, 2015 | 11:15 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds more like the typical IAC issue, or the PCV elbow issue.
Old Nov 6, 2015 | 09:03 AM
harley4jcs's Avatar
harley4jcs
This seems to do the trick. I would recon the leak down is in the injectors ?? REPS sent,Thanks
Old Nov 6, 2015 | 09:05 AM
harley4jcs's Avatar
harley4jcs
Not familiar with either of the above issues. Would you please elaborate ?? Thanks
Old Nov 6, 2015 | 10:07 AM
projectSHO89
Fuel pump, most likely. Not injectors. If it were injectors, you'd have a much bigger issue (potential hydro-lock, fuel-diluted oil, etc).
The FP has an internal check valve. It's probably worn out.
It's not an IAC or vacuum issue if the cycling resolved the symptom. You could install a fuel pressure gauge and actually see what's the pressure in the system.
waumpuscat
Mar 4, 2014 10:28 PM
hcraw4d
1983 - 2012 Ranger & B-Series
Dec 11, 2012 06:54 PM
beetlebarn
Aug 28, 2006 10:38 PM
MazdaNoZoom
Jun 27, 2004 10:25 AM
f150-az
1997 - 2003 F150
Jun 2, 2003 09:20 AM
