Modular V10 (6.8l)
Code P0352
Old Jul 9, 2017 | 09:52 PM
Fuha's Avatar
Fuha
Code P0352
Little history. Been fighting a P305. Put I new coil on it (BWD) as it was all they had in stock. Misfire cleared but returned. I installed a new plug there just trying to get the misfire to go away. It's cleared up but returned.. Today I pulled all the coils from cylinders 1-5 inspected them all and switched them around. I also pulled all the injectors from that side and cleaned them and reinstalled them switching them around. Went on a test drive. I still had a high speed misfire it felt like to me. Watching torque pro the whole time and having the "total misfire gauge on" it never registered a misfire. It would go to 1 then go back to 0. I know the gauge worked as I was setting it up last night I registered over 5k misfires sitting at idle in the driveway. After about 30 miles I stopped at my parents house to pickup my daughter and when I restarted the truck I had a check engine light and code "P0352". I assuming this deals with cylinder number #2?
I can look to see where the coil from 5 ended up it may be on 2 now I can check in the morning.
Old Jul 10, 2017 | 10:13 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That SHOULD indicate a circuit failure of some kind with cylinder #2's COP. You changed the coil, but did you change the boot too?
Old Jul 11, 2017 | 09:25 PM
Fuha's Avatar
Fuha
Yes all the old coils got new boots. I also confirmed that the new coil is on cylinder 2 now. I will be taking it off and returning it. See what happens after that
Old Jul 16, 2017 | 07:24 PM
Fuha's Avatar
Fuha
Got the coil pack off and switched out. Have no more misfires as of now.
It did jump on me at a red light and then die on me at low rate of speed about 20mph. It fired right back up. I will continue to monitor it see how it acts.
royeco
Jan 25, 2017 01:26 PM
pooneee
2004 - 2008 F150
Jun 1, 2010 07:08 PM
njxlt
Apr 21, 2009 07:07 PM
Soul-tez
3.8 & 4.2L V6
Mar 17, 2006 04:19 PM
bassin
Modular V10 (6.8l)
13
Jan 14, 2005 11:09 AM
