Sponsored by: Auxito
Steering Damper?
Old Jul 8, 2017 | 11:35 PM
Lime1GT's Avatar
Lime1GT
Question Steering Damper?
My 02 F150 4x4 at times gets a shake through the steering when hitting road cracks, pothole fills, etc. Would installing a steering damper system help or am I missing something to check in the front end. Ball joints are good, all steering linkage good, new shocks all around, control arm bushings look good and don't seem to shift when prying with a bar. Also changed all sway bar bushings and links. Maybe the control arms just have to be changed with 103,000 miles on it even if they appear OK?
Anyone else using an aftermarket steering damper on a stock F150? My long gone 82 GMC 4x4 had one from factory but it was also a solid axle setup.
Old Jul 9, 2017 | 09:35 AM
steve(ill)'s Avatar
steve(ill)
if you were talking about off road, then maybe a stabilizer would help.... A STOCK 2002 F150 should have no shake when hitting road cracks or pot holes...... Your missing something... I normally put a jack under the A frame on each side and jack each tire an inch off the ground.. That leaves all the suspension parts in line as they would be running down the road. Then grab one tire and jerk it side to side in and out and note any slop between it and the other tire.. Could be small differences causing the problem....... then put a 4 ft 2 x 4 edge under the tire and pry up and down and inch or two.. feel for any movement in the upper and lower ball joints.. Something is not quite right.
Old Jul 9, 2017 | 09:36 AM
steve(ill)'s Avatar
steve(ill)
check you shocks also... IF ONE shock is bad, you will get sway when the truck front end bounces slightly when hitting a hole.
Old Jul 10, 2017 | 10:11 AM
Lime1GT's Avatar
Lime1GT
Thanks Steve. I'm going to do all the checks over again when I next rotate my tires.
Old Jul 10, 2017 | 10:36 AM
Bluegrass 7's Avatar
Bluegrass 7
Sounds like a combination of some wear and alignment issues.
Good luck.
Philisophe
Oct 30, 2018 10:59 PM
cpye2
129
Jan 10, 2016 08:09 PM
03X
Nov 26, 2015 09:14 AM
Whatmough
Aug 29, 2014 07:54 AM
White Boy
1978 - 1996 Big Bronco
Apr 7, 2014 05:34 PM
