carb applications question
Old Jul 8, 2017 | 10:02 PM
74f100sc's Avatar
74f100sc
Have installed Edelbrock Performer 390 (4V) intake on my '74 360...currently with original 2100 2V via adapter plate; runs well, good economy...considering 4V options including new Edelbrock or an OEM-type...what 4V's were OEM? just holley? I like the idea of an OEM look/function
Old Jul 8, 2017 | 10:08 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
nothing for a 360, but 390 probably had the autolite, like a 4300 or something. Probably not a great carb, but would think a holley vacuum secondary 4 barrel would work good, 600, 650, 670, or so. I bet one of the motocraft holley 600 cfm from a 460 would run good and look close to right.
Old Jul 9, 2017 | 02:40 AM
74f100sc's Avatar
74f100sc
after the 2100 and 2150 2V's, my clymer manual shows a 4160 and 4180, which are holley 4V's, and searching the 4180 on ebay indicates it's for the 460....so probably the 4160 was used on the 390....however, i've also seen some motorcraft 4V's on there from the mid-70s that use a tube from exhaust like the 2100 does...but the book doesn't detail those....maybe just used on cars? what's a '74 390 going to have?
Old Jul 9, 2017 | 05:32 AM
KULTULZ's Avatar
KULTULZ
Post
IMO...
To make the truck appear as OEM of the period, it will need a HOLLEY short bowl. The HOLLEY OEM 4180 was an emissions carburetor and while can be modified for more performance a modern replacement HOLLEY (600cfm) would be easier and cheaper.
Are you planning on retaining any of the emission controls (or not)?
Old Jul 9, 2017 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ALL 1968/73 390 and 1968/78 360's came with 2V's. 1974/76 390's were available with 2V's or optional 4V's.
Old Jul 14, 2017 | 11:46 AM
74f100sc's Avatar
74f100sc
I meant what would be OEM w/390 in a 4V (?)...I believe the 360 can benefit from a 4V with aftermarket manifold...the engine originally used an EGR carb spacer, but the Performer 390 is non-EGR, and i don't know of any EGR-compatible 4V aluminum manifold available for this engine...a new 600 Holley seems a good option- one hassle with an Edelbrock carb would look to be the different area where fuel connects
Old Jul 14, 2017 | 12:02 PM
NumberDummy
I meant what would be OEM w/390 in a 4V?
1974/76 F150/350 - VIN engine code M = 390 4V
Holley 4V's were optional for these trucks. A/T (C6) different carb than M/T .. Sold new in CA trucks used different Holley 4V's.
Old Jul 16, 2017 | 01:02 AM
Ozzie H.'s Avatar
Ozzie H.
It should have been a Holly 4160, but as Bill said linkage variations occurred.
Nseal1996
Jul 1, 2014 12:15 AM
HillBillyBuddha
26
May 13, 2013 01:34 PM
Mr. G
34
Jun 6, 2012 09:39 PM
tandm19992000
21
Feb 22, 2007 08:27 AM
marilyn
Jan 9, 2007 07:35 AM
