engine compartment harness oddities
Old Jul 8, 2017 | 01:51 PM
GoldCo's Avatar
GoldCo
Exclamation engine compartment harness oddities
95 5.8
1) there is a connector with 2 wires that is the closest one downline from the MAP sensor... one wire is purple, which when i trace back to the PCM and check my diagrams, it says "not used". the other wire if i recall is R/Y. the connector has no cap, like other ones not in use. ideas??
2) i bought a new O2 sensor, and the connector was male... but the connector on the harness is also male. i looked at other sensors online and they're the same. went to junkyard and snipped one from a '94 which was female.
was '95 different for some reason?
PrEDRiSing
1983 - 2012 Ranger & B-Series
Aug 11, 2018 03:44 PM
Intimnasc
Apr 22, 2013 05:06 PM
ewford
Dec 28, 2012 04:20 PM
Cdy1
1978 - 1996 Big Bronco
Jan 2, 2009 06:13 PM
