Installing a headlight harness...
Old Apr 28, 2019 | 01:56 PM
1TonBasecamp's Avatar
1TonBasecamp
Originally Posted by John89
One more question, did you leave the stock ground wires in place?
Yes, always. At least on stuff like this.
The only thing you're usually changing with a relay setup is the positive side of things. So the lights still need a good ground to function.
If you disconnected the ground, nothing would work until you re-attached it.
While you're there though, make sure the terminals and the surface under them is clean and tidy.
I usually scrape/sand/buff the metal, clean the connectors or replace them if they're too corroded, and then once it's all buttoned back up, spray a quick spritz of paint over the top to keep future rust to a bare minimum.
But as long as you just make sure the existing ones are clean, you're at least decent shape.
Paul
AngelesCrest
Mar 20, 2018 01:38 PM
thegenco12
Appearance & Dress-Up
Jul 6, 2016 09:30 PM
sere0501
Feb 21, 2016 10:39 PM
Sunline Fan
Dec 20, 2011 01:35 PM
