Hey guys. I bought a 69 Lincoln with a 460 in it for the 79 f250 I'm building. I also picked up a 69 429. Both engines have the crank driven power steering pump which I'm not using for obvious reasons. Is that crank longer in the front to accommodate that setup or is it the same as the later ones. I'm using AC as well and trying to figure out pulley or possible serpentine setup. Any help is greatly appreciated!
Vickers Drive crankshaft driven P/S pump:
1957/60 Mercury 383/430; 1957/65 Lincoln 430; 1959/60 Thunderbird 430; 1966/68 Lincoln 462; Some 1968/69 Lincoln/Mark III 460.
Thanks for all the help. Going to drop the engine off at the machine shop this week. I'm a long way off in this project and I'm sure I will have more road blocks. Thanks again, and in advance, for the next one!
