Trying to get an old truck running better, new to me project rig. Went to check timing today and have found NO timing pointer. Looked all over on line and not much seems to be available for an inexpensive option. Does anyone have a recommendation ?
I found this: https://www.summitracing.com/parts/pfs-92009/reviews/ Professional Products Timing Pointer Ford FE Engines with 7.5" Damper
It shows compatible with older FE engines, will this fit on the 89 engine ?
