So my Excursion got wheels from a E350 that's has a different bot pattern. What I'm wondering on is how expensive the repair is? The bolt pattern to the Ex is 170mm, and the patten to Econoline is 165. Can't be safe to run is it?
Ford Excursion, '00-'02= 8 x 170mm, M14 X 2.0 Nut, 124.9mm center bore.
Ford E350 = 8 x 165.1mm
I don't think the E350's are going to fit your Excursion without some sort of adaptor.
If they're already on, did someone modify the Van rims to fit the Excursion?
I'd remove them, find some 8 x 170mm rims and check to see if your 8 lug nuts/studs are un-harmed. Did they use Excursion 'washered' lug nuts or the acorn lug nuts that came with the van? (maybe vans are washered also now?)
