Column shift c4
Old Jul 7, 2017 | 09:26 PM
DDB1973's Avatar
DDB1973
Column shift c4
I have a 1973 f100 column shift with a c4 trans. The rod that runs from steering column under the hood, to the transmission it's twisted and bent. And the bushing at column looks to be in a bind. I've been to the salvage yards. Each rod I bought was too short. Any suggestions on after market? Photos would be helpful. Thanks
Old Jul 7, 2017 | 10:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
According to the Ford parts catalog there is only one transmission shift rod for the 73 with a C4. This rod actually covers just about all applications.
Manual shift rod
Fits: 73-77 F100-350 2WD, all engines and FMX, C4 or C6 transmission
73-77 F250 4WD before s/n X80,001
18 21/32" long 7/16" diameter
Part number D3TZ-7326-A
The only other rod it shows for 2WD is the 78-79 F100-350 all engines all auto transmissions is P/N D8TZ-7326-A and its approx. 19.16" long.
EDIT:
Is this the original transmission? Is there a possibility that a different transmission has been installed and doesn't have the correct shift arm for truck applications?
Old Jul 8, 2017 | 05:43 AM
DDB1973's Avatar
DDB1973
Shift rod
Good morning. Thanks for you reply. My truck was stolen years ago. Motor and trans were both taken. So yes. As best as I can research my transmission is out of a car. According to trans shop. I'm going to use those part numbers and conduct a search. The shift rod I have looks like it's been twisted and bent. And I seem to destroy the bushing at column every time I force it in. I will post some photos of what I have .Thanks DB
Old Jul 8, 2017 | 09:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If the transmission has been replaced with one from a passenger car then that's probably where your problem is. The shift arm on the side of the transmission is different between cars and trucks.
The part you need is D3TZ-7A256-A. That shift arm fits all 73-77 trucks with a C4. Unfortunately its a discontinued part and no dealer or obsolete parts supplier shows having one in stock.
72CC428
Dec 7, 2018 08:25 PM
72CC428
Nov 19, 2018 10:55 PM
Uni Moe
Feb 4, 2015 07:13 PM
droppedf100
Jun 22, 2011 04:50 PM
dawfun
Aug 30, 2010 01:08 AM
