AC Compressor oil check procedure
Old Jul 7, 2017 | 04:03 PM
orangeford's Avatar
orangeford
I just recharged my Factory AC system already converted to 134A after I had a condenser leak and replaced it. O'reilly's lifetime warranty came in handy there. Pulled a vacuum and followed all the procedures to charge.
At idle or low speed cruise the compressor rattles like a bad rod bearing. Is this normal? I would like to check the oil level in the compressor and it is my understanding that it can be isolated without discharging to do so.
Anybody know what position the valves need to be screwed to, in or out and if the bolt on the top is how you check oil level?
Old Jul 7, 2017 | 05:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a link to the service manual for the York A/C compressor.
The procedure to check the oil level is on page 7.
http://www.240.se/litteratur/york.pdf
Old Jul 10, 2017 | 10:57 PM
orangeford's Avatar
orangeford
Ok thanks I found the procedure in my ford manual as well. I isolated the compressor with the service valves and I managed to not drain enough pressure out the high pressure service port and lost enough threads that the oil plug went flying to outer space, who knows where in my garage. I cannot find it now and need to know what the thread size is so I can try to find a replacement? It was a 1/2" hex size.
By the way oil was really low I hope I didn't damage the bearings bad. I was planning a to do the serpentine conversion with a new compressor but not now.
My daily just blew the motor and now tranny too after replacing the motor.
silverorange
Jun 23, 2017 04:08 PM
annaleigh
Apr 1, 2016 04:30 PM
daveya48187
1983 - 2012 Ranger & B-Series
Jun 15, 2013 07:06 AM
HENDEL JR
Jul 30, 2005 02:25 PM
Boyd1971
Jun 23, 2004 10:21 AM
