brake light problem
Old Jul 7, 2017 | 02:53 PM
Zacbkennedy's Avatar
Zacbkennedy
brake light problem
i have a 1977 f100 the front turn signals work perfectly even with headlights on. drivers side tail light works perfectly with the turn signal, brake, and headlight. the passenger side tail light works for the brake and turn signal and headlight but not all at the same time. if i have the turn signal on and hit the brake its like they cancel each other out and the filament does not light up. i took off the assembly and they all light up the same filament (dual filament bulb) is it the turn signal switch?
Old Jul 7, 2017 | 04:04 PM
deich's Avatar
deich
Possibly... my gremlins came from the switch in the column.
Definitive diagnosis was if I just ever so slightly lifted the switch lever the brake light came on was working.
Old Jul 8, 2017 | 12:11 AM
meangreen92's Avatar
meangreen92
It could be the socket. If you have a multi-meter, you can check for 12V+ from each wire which goes to a filament. And also check to make sure the socket is actually grounded. There should be a ground wire to the body behind (actually in front of...) the tail-light assembly. Your symptoms sound like a bad ground, or perhaps the bulb is in the socket 180º backwards.
Ford ranchero
Electrical Systems/Wiring
Apr 12, 2017 10:33 AM
Evel K
Jun 26, 2014 08:34 AM
DBGrif91
May 10, 2011 10:45 AM
rmalottwtes30
Sep 14, 2008 01:07 PM
tmcalavy
Sep 2, 2001 05:02 PM
