I have an F350 Lariat Superduty Crew Cab (6.0L Diesel).
I jackknifed a trailer to the passenger side causing the after market MBRP exhaust to get bumpted and moved around.
I heard a crunch and the truck immediately started running rough with no power. The truck would start and go, but no power for a few days. It sat over the weekend and then cracked slightly with some difficulties and then NO START.
Its at the dealer, but I'm terrified what it could be. Has anyone ever exerienced a similar situation? Any ideas what I &%$#ed up?
I did climb under. The exhaust has moved a lot like I mentioned. That is all I can see from underneath. The pipe is solid all the way back to the turbo. I'm wondering if the pipe movement damaged the turbo?
