V10 cylinder head and intake issue
Hello, long story short, I have a 99 F250 4x4 V10, with a blown up motor. I got a very low miles engine out of a F53 chassis, swapped the parts to drop it in the truck. I am new to the V10 world and apparently there are a W head and a PI head. My question is, are the intakes different? My new motor is a W head, will the PI intake fit and work or do I have to use a different intake? I know this may be a common question, but I don't have time to go threw all the V10 threads to find the info I need. Thanks for any help!
on
Stamped in the part number of the head just above the exhaust ports, the early non PI heads will say "6.8L W" on the top line and the second line will be a long part #.
It means Windsor.
The later PI heads will have the letters PI conspicuously stamped in the part number of the head just above the exhaust ports.
It means
Power
Improved
They made more power, which was such a noteworthy improvement that Ford designated the heads as such in the part # stamping.
Also, the chambers and port runners are different volume, the intake ports are a different shape, the pistons have a different shape.
If you want to tune it and get the most out of stock off the shelf V10 parts, you would put a set of PI heads on your early non PI short block along with the PI intake. This will net a small but noticeable compression boost as the early piston will make more compression in a PI head than the PI piston. I am sure someone will correct me or add specific specs and part numbers but that is the gist of it.
You're welcome.
Dunkit
03-07-2019 10:36 AM
trinogt
13
07-15-2003 08:37 AM
