Body panels...
Old Jul 5, 2017 | 05:07 PM
LadderDogV10's Avatar
LadderDogV10
Body panels...
My 67 project will be arriving on Monday from the transport company and i'm just planning ahead on purchasing some body panels.
My question is am I better off locating nice clean used panels or buying aftermarket panels? I know original panels may need some body work and there and the aftermarket may or may not. But how is the fitment of the aftermarket ones? Is their a company that seems better than another ( LMC, DC ETC)? I guess are there any advantages of original panels over repo?
I will be looking at needing fenders, 1 door, inner fenders, core support, tailgate and possibly a hood
Thanks all!
Old Jul 5, 2017 | 05:33 PM
KOT390's Avatar
KOT390
I'm going to say that Original panels are probably a thicker gage steel, made at the Rouge in Detroit rather than Chinese stuff. I guess it depends on what you are wanting when you're done. I don't know for a fact though on the thickness comparison...
KOT390
Old Jul 5, 2017 | 05:34 PM
lilorbie's Avatar
lilorbie
imo. always go with Ford stuff if it,s easy to get. also try flashbackf-100. i have heard good things about them. they sell O.E.M. fenders, doors, etc. not sure about how much they would be. do not use LMC for anything unless they are the only one who has what you need. their patch panels are junk. do not ask me how i know this.
Old Jul 5, 2017 | 07:52 PM
SteveJH's Avatar
SteveJH
Thanks all!
I'd recommend looking for a donor vehicle in New Mexico or Arizona. I've never used aftermarket sheet metal in a Ford, but from my experience with old European cars repops are usually very inferior to OEM steel. The steel is of a thinner gauge and the metal itself is cheaper, plus they never fit perfectly or look exactly right.
I'd rather weld together two OEM German VW fenders to get one good one than deal with a POS Chinese reproduction that cost mucho dinero. I'm sure Ford stuff is the same way. In fact that's pretty much my plan of attack on my 69, but I haven't gotten to the point of major body work yet.
Old Jul 5, 2017 | 09:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All the aftermarket sheet metal in made in China. The quality varies from one repro parts seller to another. Carpenter is probably the best, LMC the worst.
Front fenders, inner fender aprons, radiator (core) support (*), Styleside tailgate, hood are the same: 1967/72 F100/350.
1967 F100/750 doors are 1967 only! 1968/72 F100/750 doors are different.
*TWO different radiators supports, the support used with the Super Cooling radiator has a larger opening radius.
I would think you could find nice rust free sheet metal in AZ & NM
Flashback F100's is located in Reidsville NC .. The owner drives thru the west (AZ-CA-NM-NV) at least once a year buying used sheet metal from junkyards.
Old Jul 5, 2017 | 09:23 PM
SteveJH's Avatar
SteveJH
Hey NumberDummy, I don't mean to hijack a thread but I was planning to swap some dry doors out of a clean '72 into my rusty turd of a '69. I planned to take them apart, spray inside with rust encapsulator, clean then up and paint them with Rust-Oleum, and swap the interior pieces and build tag for my 69 onto them then bolt them on. Am I missing some critical info?
Old Jul 6, 2017 | 08:49 AM
NumberDummy
No.
1968/72 F100/750 doors are the same.
Old Jul 10, 2017 | 06:51 PM
LadderDogV10
Picked up a set of nice original fenders locally $100.
Old Jul 11, 2017 | 07:24 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Go with the original stuff as much as possible. I got cab corners from Dennis Carpenter, and they didn't line up well at all. Luckily, I found a set of cab corners from a buddy that cut them off for me, and I used the DC corners to patch the small areas on the factory corners I got.
Baby Boomer
Jun 6, 2017 10:05 PM
roger dowty
Paint & Bodywork
Apr 24, 2006 02:28 PM
89bronco guy
1978 - 1996 Big Bronco
Jun 13, 2004 07:39 PM
Woodrow
Nov 17, 2003 02:46 PM
dbarracuda
Oct 2, 2003 08:59 PM
