Not really sure on the proper words to use to search for this. I'm swapping a set of '06 SD axles under my '97 dually. My current problem is that the rear axle is a SRW not a DRW. If I cannot swap the rear with the local JY for their DRW, I was wondering what differs on them.
Also I can't find the dually adapter for the front axles for the 05+ but I can find them for a 99-04, is there a difference in them?
Parts needed still:
Front axle adapter
Spring/shock tower
Maybe rear leafs/hangers
Rims/tires (debating on aftermarket or Alcoa rims)
