Wrapped headers?
Old Jul 4, 2017 | 08:31 PM
bulldogcountry1's Avatar
bulldogcountry1
Wrapped headers?
My dad and I put plain finish headers on my 78 F250 400 about 15 years ago when it was his daily driver. For some reason, he soon after wrapped the headers. I can't recall if he was experiencing any heat issues.
The truck is mine now, and the wrap has disintegrated. I haven't had any overheating problems since I removed all the wrap, and I was debating on rewrapping or coating with something. Either way, it won't be an easy task, and I won't bother if it's not necessary.
If anyone can share their experiences with heat-related problems due to headers, wrapping, coating, etc., it might help me out.
Old Jul 4, 2017 | 08:45 PM
400 '77 F150 Ranger's Avatar
400 '77 F150 Ranger
It hasn't happened to me and mine are unwrapped, but I've heard of people having issues with too much heat on the starter. I'd have to believe most are unwrapped unless you've done a lot of engine work.
Old Jul 4, 2017 | 08:57 PM
Blue and White's Avatar
Blue and White
15 years on wrapped headers is pretty darn good. The wrap holds heat which can degrade (crack) the headers. Also moisture than can rust them. Personally, I would not re-wrap. If heat is an issue, ceramic coated (inside and out) is a better option.
Old Jul 5, 2017 | 07:58 AM
JD Q's Avatar
JD Q
a year ago I installed long headers on my 400. I don't like the headers to rust, so I scuffed the outside of the headers with a gray scotch pad and sprayed a high heat black enamel on the outside. I also tried Eastwood Hi-Temp Internal Exhaust Coating. Eastwood Hi-Temp Internal Exhaust Coating w/Nozzle
A year later the headers look very good compared to the glass packs that are rusted up just next to the collector.
Hope this helps.
Old Jul 12, 2017 | 04:24 PM
bulldogcountry1
Upon further review, I've got some flaking caused by the wrap. I think I can salvage them, or at least buy a few more years with a good paint coating.
The Eastwood stuff doesn't exactly have rave reviews. I'm looking at other brands like DEI, VHT, POR-15, and thermo-tec that have pretty good reviews. Anyone got experience with any of these products?
Old Jul 16, 2017 | 09:41 AM
bryanmartin's Avatar
bryanmartin
Don't wrap unless it's a dedicated race truck. The radiant heat is not much, and wrap will rot your headers very quickly if they get wet. Correct, ceramic coating is the best, but pricey. If you're having starter heat-soak problems (rare on a Ford, more of a Chevy thing), then the best idea is to wrap the starter itself, not the headers.
Old Jul 16, 2017 | 10:25 AM
DB429SCJ's Avatar
DB429SCJ
Hedman and Hooker both advise against the use of wrap, due to excessive heat build-up and moisture retention. They also state that its use will void all warranties.
Old Jul 16, 2017 | 05:40 PM
Shortbox4x4's Avatar
Shortbox4x4
I've had headers on my '68 Firebird 400 (has 550hp 462ci in it), my headers on my '70 Bronco, my pipes on a '95 VMAX and just had my factory exhaust manifolds on my '77 F150 with a 460 in it all Jet Hot ceramic coated. No rust, no flaking etc...and they run cooler and cool down superfast. How fast? Good example is the Vmax. Drove it for a half hour at freeway speeds to the ice cream stand. Shut it off. Went up and got a sundae and walked back to the bike. Leaned my legs/calfs (had shorts on) right up against the pipes. Barely warm to the touch. No burns etc...
Later, Shortbox4x4
F-250 restorer
Mar 27, 2018 10:27 AM
mtntop1
Aftermarket Products
Oct 24, 2013 10:54 PM
justforkicks
Jun 19, 2011 01:52 AM
admiralturbo
Bronco II
Oct 24, 2004 12:03 PM
1979f_100
Jun 30, 2003 11:47 PM
