I doubt it - block/intake height and other things are different I'm sure.
Are the 460 dizzies the smaller-diameter size like the FE dizzy? You could swap the internal parts if so. I know in '76 or so, they were using a small-diameter distributor on the FE that had the Duraspark internals.
The distributor gears are the same if they have the same shaft size.
The only distributor that will fit a FE is one made for a FE.
351C-351M-400-429-460 share the same dist that will not fit a FE.
