A/C & defrost issues
Old Sep 5, 2003 | 02:14 PM
kaurihudson's Avatar
kaurihudson
I just bought a 1989 F-250 460 EFI with 92K miles and when I turn on the A/C it does not blow cold, which I am guessing means it needs to be recharged? Additionally, it also seems to affect the power of the engine when you turn the A/C and/or defroster on at all. It makes the engine lurch when either is on. Any suggestions on what that might be? Or should I just recharge it and get used to the affect it has on the engine?
Any suggestions greatly appreciated.
Old Sep 14, 2003 | 02:52 AM
paultsr's Avatar
paultsr
The lurching doesn't sound good at all. There's a pressure switch in the freon line which is supposed to keep the A/C clutch from engaging if you lose your freon pressure. The freon carries the oil needed to lube the compressor. If the switch is not working, the compressor will turn without lubricant and eventually fail. Fist thing to do is pop the hood (with the engine off!), try turning the compressor over by hand. If its tight, its toast.
Old Sep 14, 2003 | 07:53 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
If you don't know A/C systems, you will likely do more damage than good by working on the system. Troubleshoot the electrical part, switches, fuses, etc. If you need to go beyond that, learn A/C or get help.
You can get certified to work on motor vehicle A/C online, EPA section 608. There are many good manuals out there that explain the workings of A/C.
When you understand subcool and superheat and why moisture is an A/C system's enemy, then you are on your way.
Old Sep 14, 2003 | 08:50 AM
larry derouin's Avatar
larry derouin
the "lurching" is your compressor cycling on and off when you put the selector in A/C or Defrost. It does put a small to moderate load on your engine.
Get the system checked at a shop, and have it changed over to R-134. It will be cheaper than trying to repair the system and then getting R-12 put back into it. R-12 is getting prohibitively expensive for the average joe to get put in. The R-134 works almost as good.
Old Sep 14, 2003 | 10:26 AM
94van's Avatar
94van
You can get certified for Section 609 , which allows you to purchase 12 oz. cans of R-12. Certification costs $15.
R-12 can be purchased on eBay for $18&#177 per can.
Old Sep 14, 2003 | 04:25 PM
goofy173's Avatar
goofy173
I just bought 3 cans of R-12 for $7 each off of Ebay.
Old Sep 15, 2003 | 12:09 AM
paultsr's Avatar
paultsr
I've never tried an R134 conversion before though I've seen the kits. Is there an expansion valve change that needs to be done?
