Ford 330 Options
New to the forum, thought maybe some of you could help... We have a Ford 600 on the farm we use as a grain truck. It has a 330 engine in it. 4 years ago, it got a crack in it and had coolant in the oil. We took it to a local shop who discovered the crack and suggested sending it off to be rebuilt by Jasper. He arranged for this and informed Jasper of the crack which they said they could fix. We got the engine back and installed it. We then used it one season hauling grain with good results. The next season, same deal. At this point, it had about 540 miles on the engine.
Last fall, I got it out and had no brakes. I couldn't get them working and so we took it back to the same shop. Of course, this was during harvest season. Upon driving it there, my dad noticed it wasn't running well. The brakes got fixed and the mechanic started diagnosing the running issue and found a lobe worn off the cam in the 540 miles. It was repaired, Jasper didn't stand behind it, and we dropped some more money into the truck.
We got it back after harvest was over and drove it 9 miles to put into the shed. This was last fall.
Dad got it out last week to start it and run it a bit. The battery was dead, so he bought a new one and installed it. It started and ran 2-3 minutes and died. It was restarted and died in another 2-3 minutes. Somewhere in there, he noticed it did not register oil pressure on the gauge. On the second "died" he tried to restart it and it wouldn't turn over.
The mechanic was called out and he found he couldn't pull the distributor out. He came back another day and found that 4 cylinders are siezed, antifreeze in the oil again, and the crack not fixed and leaking again. The engine, now with ~550 miles on it, is trashed.
So, barring Jasper standing behind this thing, we're looking at options. 1.) bother to fix it again? 2.) what other engines could be put in place (the mechanic couldn't find a 330 when this one was fixed)? Other ideas? We've put a lot of money in the truck (brakes, tires, you name it, and it's worthless now...
So, can anyone suggest replacement engines that might be easier to find that would bolt into the 330 hole?
VIN is C60CU809980.
Thanks!!!!
New to the forum, thought maybe some of you could help... We have a Ford C600 tilt cab on the farm we use as a grain truck. It has a 330 engine in it. 4 years ago, it got a crack in it and had coolant in the oil. We took it to a local shop who discovered the crack and suggested sending it off to be rebuilt by Jasper. He arranged for this and informed Jasper of the crack which they said they could fix. We got the engine back and installed it. We then used it one season hauling grain with good results. The next season, same deal. At this point, it had about 540 miles on the engine.
The mechanic was called out and he found he couldn't pull the distributor out. He came back another day and found that 4 cylinders are seized, antifreeze in the oil again, and the crack not fixed and leaking again. The engine, now with ~550 miles on it, is trashed.
VIN is C60CU809980.
C = 330 2V Medium Duty FT engine.
U = Louisville KY Assembly Plant.
809980 = 1966.
The 330 2V Medium Duty is the most common FT engine, installed in 1964/78 500 and larger series trucks.
Other FT's are the 330 2V Heavy Duty, 361 2V and 391 4V.
I suggest getting another 330 2V Medium Duty, as the flywheel, clutch and etc. parts used with the other FT's are different.
Thanks
Keep the board posted please...
Be careful if you look for an FT short block. The one referenced in KULTULZ's post says it works for 330/361/391 engines. The 330 has a bore of 3.875 inches. The 361/391 engines have a bore of 4.05 inches.
Note ND's comment that the 330 bits do not directly swap if you find a 361/391 block.
To Wit-
It came out of Ford powered bus. The FT engines were for heavy duty trucks and buses. This was a 2 bbl carb motor. It turns freely and cylinder walls are in good shape and have minimal ridge line. Included is what is in the first 4 pictures with exception of harmonic dampener, timing chain cover and front motor mount. These engines haven't changed much from 1964 to 1978. I'm unsure of the other aspects of the engine because I haven't pulled the oil pan off and didn't hear it run. I would recommend you go through it and have it checked.
I have other 330 361 391 Ford FT parts available (torque converter, flywheel, intake, heads, etc). Let me know what you are looking for.
...the advertiser has either a yard and/or repair facility where he can gather all of this.The OP has all ready been the JASPER route. It's either this or a re-power.
I wish I was younger as I would start my own parts business regarding FT and SD. Seems to be a demand for them.
OP- About where are you located?
I did read the post and the ad, for what it's worth. That may be the best option going, I just don't know right now.
Again, I appreciate everyone's input here.
Thanks
E-Bay will give the location of the seller and if not close, they will give you shipping rate. The purchase is guaranteed, read closely.
Local salvage yard. If they don't have it they can locate it.
Good Luck with it. I am surprised @ JASPER. Didn't use to be like that.
Their stock number on car-part was J51584.
I'll report back, hopefully with good news, when we get it in the truck.
We installed the 391 on Saturday. Took a little interchanging of parts from the 330 to it, but went in pretty well. Got it running, and had to rebuild the carburetor. That got finished yesterday and it runs pretty well.
A huge thanks to this forum for the help! It was here where I got the lead for the engine and your advice on what would and wouldn't fit was tremendous. Thanks so very much to all of you!
