Engine issues again
Old Jul 3, 2017 | 11:34 AM
wetbiker's Avatar
wetbiker
Engine issues again
I got out of home depot and theres a small puddle of oil under the truck. open the hood and it looks like oil is shooting out from somewhere on the pass side. The Ac box, pass valve cover, and turbo down pipe have oil on them. The oil looks like its shooting onto the bottom and side of the down pipe. I ordered some new vc gaskets, is there anwhere else the oil could be coming from. I had it idling in the driveway and I dont see and oil shooting out. Is there a way to rev the motor from the engine compartment?
shem
Old Jul 3, 2017 | 12:00 PM
TooManyToys.'s Avatar
TooManyToys.
Based on your other post about what it would be worth selling you mention a new HPOP. Another member here had that type of oil leak just before his HPOP line blew out at the rear plate. How confident are you about that repair and the gaskets/connections coming off the HPOP?
Old Jul 3, 2017 | 12:23 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Did you seal the HPOP cover with grey RTV at the seam between the block and the rear cover?
Old Jul 3, 2017 | 12:35 PM
wetbiker's Avatar
wetbiker
I used the red rtv, is the grey high temp too? I guess it could be the hpop gasket, its def in that area. I had everything clean and did it the same way ive done every other gasket. Ive worked on cars my whole life and never had as much trouble with an engine.
shem
Old Jul 3, 2017 | 01:40 PM
texastech_diesel
Token Redneck
As I understand it the grey stuff (Motorcraft TA-31 is the OEM spec) is formulated to resist oil seepage while being more flexible at the correct temp rating. I have no idea how stable the junction between the block and rear cover is, but an engineer specified grey for a reason.
Old Jul 3, 2017 | 02:06 PM
bismic's Avatar
bismic
The TA31 is for high(ish) temps and for oil resistance.
Old Jul 3, 2017 | 02:30 PM
wetbiker's Avatar
wetbiker
Ok thanks fellas, ill do it w the grey and a new gasket. Still selling the truck
shem
Doctomario777
1983 - 2012 Ranger & B-Series
Mar 22, 2013 03:20 PM
JessieDM
Apr 24, 2011 09:59 PM
ewellman
Mar 18, 2011 06:03 PM
95mazdab2300
Jan 7, 2004 05:21 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
Oct 2, 2003 09:42 AM
