No start
Old Jul 3, 2017 | 08:57 AM
bcamill's Avatar
bcamill
No start
OK, I have been through the tech tips and tested what I could. The pick up rivets were loose and the reluctor dug into it. I figured I found the problem. No luck. The coil is putting out 6.7 volts to the top of the cap with key on. Still no spark at plugs. I just do not get it. 83 Ford F100 302. all stock
Old Jul 3, 2017 | 11:43 AM
Franklin2's Avatar
Franklin2
Have you changed the ignition module?
Old Jul 3, 2017 | 01:41 PM
bcamill's Avatar
bcamill
That is the one part i threw at it
Old Jul 3, 2017 | 02:50 PM
Franklin2's Avatar
Franklin2
Take your meter and put the red lead on the coil negative, and put the black lead on ground. Get someone to crank it over. Does the voltage go up and down when it is cranked?
Old Jul 4, 2017 | 09:14 AM
bcamill's Avatar
bcamill
It does. I think I have a bad ground I need to find.
Old Jul 4, 2017 | 01:48 PM
bcamill's Avatar
bcamill
I get a constant 2.12 on the negative side
Old Jul 4, 2017 | 04:30 PM
Franklin2's Avatar
Franklin2
That's not good. The voltage should go up and down, that is the ignition module turning the coil on and off. It grounds the neg of the coil, and then ungrounds it to make the spark.
I would do some checks on the pickup module inside the distributor. In this link are the resistance checks you can do on the module inside the dist.
Dura Spark II
Old Jul 11, 2017 | 10:39 AM
bcamill's Avatar
bcamill
OK, I got to the bottom of the issue. I wanted to share for others. The pick up in the distributor became loose and the reluctor slam into it. This caused the pins on the reluctor to shear off. Thus, the reluctor was not spinning and the circuit would not open and close. I replace the distributor just in case the shaft was also damaged. Fired rght up.
Old Jul 11, 2017 | 04:08 PM
FuzzFace2's Avatar
FuzzFace2
Thanks for letting us know what it was as it may help others.
Dave - - - -
NashvegasMatt
17
Apr 6, 2018 01:53 PM
MitchellD
19
Aug 5, 2017 08:14 PM
krazyness
Oct 18, 2016 05:28 PM
Slyreaper
Apr 26, 2013 09:54 PM
KUE798578
36
Nov 6, 2012 11:18 PM
