motorcraft 2150
Old 07-02-2017, 07:50 PM
Gunnerboy's Avatar
Gunnerboy
Gunnerboy is offline
motorcraft 2150
I just got my 2150 motorcraft rebuilt and have some questions, First the black cap that says lean on it is cracked is that my choke? I have a vaccum choke pull out i think its called, And does anyone know of a adaptor plate for this carb to go from the 2150 to a holley 4 brl port? And is there any diagram for hooking up the vaccum ports or does it really matter? Engine is a 300 six. Thanks
Old 07-03-2017, 04:58 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
Yes that is the choke cap. You will need the CARB ASM TAG NO to source a correct replacement.
-CARB ADAPTER - 2V TO 4V-
Old 07-03-2017, 05:17 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
It matters but it depends on application/modifications. About what year and are you retaining emission controls?
Old 07-03-2017, 08:11 AM
Gunnerboy's Avatar
Gunnerboy
There is a tag I'll take a look, and it's going on a 85 bronco 300 six no emissions other than a cat. I'm new to carburetors so this is foreign to me.
Old 08-07-2017, 03:49 PM
Gunnerboy's Avatar
Gunnerboy
Ok so vaccum lines are all hooked up on my carb its old enough i didnt see one for a egr or emissions other than EVAP. But what is this fitting on my choke? and can i swap this manual adjusting one for a electric one off another carb? Being its already cracked..
Old 08-08-2017, 03:44 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
Click on URL below to read an explanation of the 2150-
Motorcraft 2150 2V Carburetor
Anything else, just ask...
Old 08-08-2017, 09:29 AM
Gunnerboy's Avatar
Gunnerboy
Hmm alright so that is for a hot air tube..where should i hook that up too ? I have a Offenhauser c manifold and EFI exaust. I went ahead and swapped the old cap to the electric assist one, So i now need to run a wire (probably 14ga?) down to the S terminal on my alternator correct?
Old 08-08-2017, 11:37 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
ID number marked on choke housing in pic in post #4: TB4
D1AZ-9848-B .. Choke Housing-Non Electric - Marked TB4 (Motorcraft CM-1455) / Obsolete ~ Available NOS & from auto parts stores.
Old 08-08-2017, 12:44 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
There is (was) a full electric choke cap conversion kit for the 2100/2150/4100 carb. That would eliminate the need for a hot air source. Would that serve you better?
-Electric Choke Conversion Kit-
The OEM electric assist may not operate correctly w/o the hot air source. OEM is powered fron the ALT Stator. Follow instructions for kit. Use a relay under the hood if requires BAT VOLT to keep it out of cabin.
This is on a 4.9L carbureted?
Need photos if HI-PO'ed up...
Old 08-08-2017, 12:47 PM
Gunnerboy's Avatar
Gunnerboy
yes it would simpler is always better this is going to be a woods rig so I'm making everything simple
Old 08-08-2017, 01:16 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
If you decide to go the with the conversion kit, usually (I am only familiar with HOLLEY) the choke asm requires a fresh air source (go by their instructions) so as not to allow the choke spring to over heat and fail.
There are two methods-
Open Air Inlet (screened) And Filtered Air Inlet
Old 08-14-2018, 09:28 AM
Gunnerboy's Avatar
Gunnerboy
Alright I'm considering just doing a manual choke these electric ones are too picky, any recommended conversion kits? Also vacuum line hook up what is the port on the back towards cab under the air filter and should there be a vacuum from manifold to the carb? I got it running but can't acheive smooth 650 idle only 1200 or above
Old 08-18-2018, 04:38 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
It worked fine on mine but then again it doesn't get that cold here and the choke tends to stay closed a bit longer than it should. Wont have that problem any more for myself as I am doing a whole engine swap.
rbtom
01-03-2015 12:18 AM
gregcoll001
03-28-2010 11:43 PM
bronco-man
01-30-2008 09:31 PM
drago5451
06-14-2006 10:16 PM
ctietboehl
02-18-2005 11:20 PM
Quick Reply: motorcraft 2150
