'11-'16 FRONT bumper & '05-'07 front fascia on '99-'04 ??
I have done the '05-'07 front fascia conversion on my L99.
I'm considering trying an '11-'16 FRONT bumper
Anyone done this?
I've seen pictures of the '11-'16 bumper on a '99-'04 but not on a '05-'07
Think it will fit?
Thanks Guys!!
Anyone done this?
Think it will fit?
Thanks Guys!!
Is your '05-'07 Grille full size or the cut down version? Mine is the full length version because I have the full '07 front fascia.....
The 11-16 bumper is great for working on anything under the hood. The large opening in the center makes an easy first step even on a lifted truck. With the flat top and textured plastic don't have to worry about sliding off. The gap under the headlights makes the screws on the bottom easy to get to.
When I tried putting the 99-04 bumper on it was hitting the grill. Drilled a new hole inbetween the original two. Couldn't go any lower because the cutout for the tow hooks was hitting the tow hooks. The grill still was touching the bumper and had a bigger gap under the headlights.
Before getting the 11-16 bumper thought about getting the 05-07. Think it was 2013 and the bumper came off a 2012. Many of the 05-07 bumpers for sale around here had been around the winter for a while and were starting to rust. With all the curves, two tones, and fog lights next to the license plate thought the 99-04 and 05-07 looked like they belong more on a suv than a truck. The 11-16 looked more like it belonged on a truck with the top that could be stood on and the fog lights under the headlights.
Several people have told me they like the look of the truck. They didn't know that it is a combination of 3 generations of super duty. Makes it close enough to factory for most not to realize it isn't, but different enough for it to stand out from others.
I used the original header panel. The headlight holes were opened up to fit the 50-07 headlights. The 05-07 grill screws into the top of the header panel the same as the original. The bottom of the grill is too low to clip into the original slots. In the photos you can see the slots are visible behind the grill. Some have used zip ties to hold the bottom tight. I left it loose and it has been fine for over 4 years.
The 05-07 header panel can be found for around $100. If you have the money for it I would recommend getting it.
U
Nice work! I just received my LED bulbs, ‘05-‘07 assembly and I ordered the ‘05-‘07 header panel online today. I’ll be doing the work next week. Then the bumper and grille will be next on the list.
