Ford Pivot Storage Box?
Old Jul 2, 2017 | 05:25 PM
USAF_F250's Avatar
USAF_F250
https://accessories.ford.com/bed-pro...ble-11678.html
Are these worth a crap? I'm trying to find potential storage solutions for underneath my Bakflip MX4. Need to store, my trailering stuff... HD Bottle Jack, Grease Gun, Tire Iron, etc.
Right now I've got a milk crate with all my crap in it that I cargo strap to the bed cleats.. Pain in the butt.
Old Jul 2, 2017 | 07:53 PM
First3Quarter's Avatar
First3Quarter
Unless you just want the Ford logo, you can get em cheaper than that.
Old Jul 2, 2017 | 08:48 PM
Xwild's Avatar
Xwild
I keep looking at those too, but they block the bedlights, and the bed cleats..
So as of now, I'm still stuck with my 3 small commander totes held between 2 cargo bars. Which I then have to unload each time I want to throw the kayaks in the bed, or anything else. Keep looking at some of the sidemount toolboxes that sit below the rail so that it will clear my peragon cover. They don't tend to look like they have much useful space though...
Old Jul 2, 2017 | 11:16 PM
USAF_F250's Avatar
USAF_F250
Oh yeah, I'm aware. These are just rebranded Undercover boxes.
Yeah, that's the same beef I have with them... the search continues..
Old Jul 4, 2017 | 04:57 PM
ssamme's Avatar
ssamme
I like mine. I emptied my milk crate and still had some room left. The bed lights were not an issue for me because I transferred the lights from my F150.
Old Jul 4, 2017 | 05:21 PM
69cj's Avatar
69cj
I really like mine. Just make sure that if you tow a 5er that you get the passenger, right, side or it will block the 5er plug.
Old Jul 5, 2017 | 12:59 PM
f350ktm's Avatar
f350ktm
I have had both Under Cover and the Ford branded and they appear to be made by the same manufacturer.
I like mine very much as it is a very convenient way to access whatever one chooses to store in there.
Two ways to secure it, one top lid lock with supplied key and a cleat to lock the box to the truck when in the retracted position using your own lock. The plastic is rather flimsy and it would be easy to simply pry the lid open by hand so further securing it under a cover is a good idea.
I am able to use the tie down directly behind the swing box even with the box in the closed position if the item I am securing sits nearly cab high. The swing box is very easy to remove (just swing and lift) if further access to the tie downs is needed.
Old Jul 5, 2017 | 02:38 PM
duckduke's Avatar
duckduke
Another option ..... side mount above wheel wells 55" long.....
May not block light as bad in place........ not sure...... haven't measured the exact position of lights.
Old Jul 5, 2017 | 08:49 PM
Xwild's Avatar
Xwild
duckduke - that's the one I keep looking at.. but it doesn't seem like there is really all that much space inside..outside is only 9x9.. if they offered a metal version that made more of the 9x9 useable, it may be the ticket.
Old Sep 26, 2017 | 02:41 PM
reesestewww's Avatar
reesestewww
Does this box impede past the wheel well? In other words does it stick out further into the bed than the wheel well does?
Thanks
Old Sep 26, 2017 | 03:22 PM
ravill's Avatar
ravill
The biggest gripe I have with mine is that there is no handle to hold them from.
I went to my local hardware store and bolted some on. It made removing them WAY easier!
Old Sep 26, 2017 | 03:51 PM
cficare's Avatar
cficare
What happened to all the old "porkchop" side boxes? Need those again, but lower overall height to work under a cover. There used to be full-length side boxes that enclosed the space both forward and aft of the fenderwell and maintained the 48" wide space between a pair of them (double-end porkchop boxes). Manufacturers probably had a fit trying to fit (pun intended) most pickup models and bed lengths.
Old Sep 26, 2017 | 04:29 PM
f350ktm's Avatar
f350ktm
Thanks
Yes, it sticks out past the well by a significant amount.
Old Sep 26, 2017 | 04:55 PM
dzlbudman's Avatar
dzlbudman
Anyone have a good place for pricing on these?
Old Sep 26, 2017 | 07:52 PM
Xwild's Avatar
Xwild
Man would a set of those be nice.. might even be worth going to the local aluminum guy and having him build a set.
