Sponsored by: Real Truck
2011-2016 Perforated Grill Bar Question
Old Jul 2, 2017 | 03:42 PM
Z22ZINFS's Avatar
Z22ZINFS
I found a YouTube and I’ve seen other web pics with the grill insert below. I think it is called an insert. It is NOT an overlay. I don’t think it is an entire grill “replacement”. I’ve seen the overlays that look similar to this and I’m not interested. I contacted the poster of the YouTube and he did not know from where his employee obtained the insert. I call it an insert because in the second photo you can see the bend-over tabs that hold it in after the OEM solid grill bar has been removed. Also, in the first photo, you notice you can see through the perforations, so it know it is NOT an overlay. I’m assuming the insert is polished aluminum or SS, not chromed plastic. I’ve spent way too much of my life searching the internet to find this part.
I’m interested in this part for two reasons. First, bug and stone nicks would not show up as bad as on the OEM polished chrome ABS. Second, I think the perforations would let more air through than the overlays on even the OEM grill. Overlays are chromed plastic and I think the part in the picture is not plastic.
Old Jul 2, 2017 | 06:23 PM
82_F100_300Six's Avatar
82_F100_300Six
Please forgive me if I'm missing something but is that not just a platinum grill?
Old Jul 2, 2017 | 06:26 PM
auburngrad's Avatar
auburngrad
You are correct. Just the Platinum grill. Runs a little north of a grand, probably why more don't put them on their trucks. Lots of other options at that price point.
Old Jul 3, 2017 | 05:44 AM
Deuce40s's Avatar
Deuce40s
OEM is plastic. I bet the one pictured is plastic as well. Are you 100% sure what you pictured is not an overlay? I'm thinking the term overlay means it is laying over the black grill in the back, not overlaying your factory solid trim. They're $120 bucks on fleabay.
Old Jul 4, 2017 | 05:30 AM
Bfazona's Avatar
Bfazona
That def looks like a Platinum gril. I've got a 14 Platinum and the grill has the different insert, as well as a nickel rather than chrome finish. The finish on the grill pictures is what gives it away. If it were chrome, I would believe that the inserts were swapped out but that's the entire grill setup. And Platinum grills are not cheap, up over $2,000 not $1,000 if you are buying an OEM Ford one.
Old Jul 4, 2017 | 12:28 PM
Sam I Am's Avatar
Sam I Am
I'll be glad when all the mfgrs get over the bracket look
Old Jul 4, 2017 | 04:17 PM
The Bone's Avatar
The Bone
Ford is a bit pricey on there parts. Don't know why because it drives people to put aftermarket parts on there trucks. I could use a new wheel for my SHO but $600 is a bit much FORD. Also hard to be a die hard Ford fan when you cant replace parts at a reasonable price. I currently own 4 Ford vehicles and I want to bleed Ford blue but come on Ford drop it like it's hot.
Old Jul 4, 2017 | 04:31 PM
82_F100_300Six
That platinum grill is nice but my black XL grill blows it away.
DeeDubz
Jan 15, 2017 10:39 AM
Sizver
Feb 18, 2016 09:48 PM
4x484150
15
Oct 23, 2011 12:47 PM
triple8
Dec 8, 2004 02:43 PM
