1978 - 1996 Big Bronco
Shocks
Old Sep 5, 2003 | 10:55 AM
GusK.'s Avatar
GusK.
Shocks
Is there anything special I need to do to replace the shocks? I just bought sensatrax for my 95 Bronco and don't want to be suprised halfway through the job?
Old Sep 5, 2003 | 11:06 AM
DW2455's Avatar
DW2455
Shocks
No just a can of WD-40 and basic hand tools wrench and or socket set, for the most part you dont even need a jack. Good luck DW
Old Sep 5, 2003 | 11:11 AM
GusK.'s Avatar
GusK.
Shocks
Thanks! I'll be working on it this weekend. I also have some issues with the rearend, I think. When I stop, there is a clunk and as I take off the clunk happens again. I took a jack to the rearend and got one of the tires up off the ground in park and spun it a little. There was quite a bit of play back there. Is that normal? What should a rearend job cost me?
Old Sep 5, 2003 | 11:22 AM
DW2455's Avatar
DW2455
Shocks
check and grease the slip yoke on drive shaft and while you have the drive shaft disconnected check the pinion nut on the rear end, there nortorious for coming loose. DW
Old Sep 5, 2003 | 01:05 PM
Crazyromi's Avatar
Crazyromi
Shocks
Just to beat a dead horse on the slip yoke issue. I had mine regreased by my mechanic about two weeks ago. I was under it this weekend trying to pull off the abs sensor from the top of the rear axle (to no avail, the bolt won't budge) when I notice that the boot wasn't tied down. The end closest to the front still had the metal band securing it to the driveshaft, but the rear was not tied down at all. I could just slide it back. Obviously this isn't very secure and could allow moisture and dirt to get in there. Should I zip tie this down, or is it not much of an issue?
Old Sep 5, 2003 | 02:25 PM
DW2455's Avatar
DW2455
Shocks
i put a big zip tie back on mine. DW
Old Sep 8, 2003 | 05:27 PM
GusK.'s Avatar
GusK.
Shocks
I got the job done in real good time...for the shocks. Had tires trown on as well. I am going to dig into the slip yoke issue this weekend assuming the rain lets up. I'll let you know how it goes. Thanks for your help!
Gwilkrrs
6.4L Power Stroke Diesel
17
May 31, 2020 07:14 PM
jhva
Aug 19, 2013 02:55 PM
brandon.edwards
Feb 26, 2013 12:15 PM
richsoucie
Mar 1, 2009 02:13 AM
quadzjr
Offroad & 4x4
51
Mar 4, 2008 03:59 PM
